Belt replacement and adjustment JD 110 1965 model
golfcartman
PostPosted: Tue Jan 29, 2013 5:46 pm    Post subject: Belt replacement and adjustment JD 110 1965 model Reply to specific post Reply with quote
Bought new belts for my J D 110 (primary and secondary) as a set. They are John deere belts . Can"t figure out what is going on with the primary belt, it seems to be too long. It is longer that the one that was on the tractor but it may not be the right belt. Can anyone shed some light on this. Part numbers match for this tractor with serial number between 15000- 40000. ( A29267). Thanks for any help.
G1355
PostPosted: Tue Jan 29, 2013 6:00 pm    Post subject: Re: Belt replacement and adjustment JD 110 1965 model Reply to specific post Reply with quote
Did someone change pulley sizes, so it spins faster or slower, just a thought.
golfcartman
PostPosted: Tue Jan 29, 2013 6:39 pm    Post subject: Re: Belt replacement and adjustment JD 110 1965 model Reply to specific post Reply with quote
Pulley size is original .
Mark-Ia
PostPosted: Wed Jan 30, 2013 1:40 pm    Post subject: Re: Belt replacement and adjustment JD 110 1965 model Reply to specific post Reply with quote
jdparts.com says Primary belt is M40015 the secondary belt is M44151
Bob
PostPosted: Wed Jan 30, 2013 11:08 pm    Post subject: Re: Belt replacement and adjustment JD 110 1965 model Reply to specific post Reply with quote
M44151 is a washer used under the headbolt of a Tecumseh engine! Correct secondary belt # is M44121.
Bob
PostPosted: Wed Jan 30, 2013 11:12 pm    Post subject: Re: Belt replacement and adjustment JD 110 1965 model Reply to specific post Reply with quote
Are you posting A29267 as a Deere # for the belts? That does not come up as a valid Deere # at jdparts.com.
Here are the dimensions of the correct primary belt, M40015:
Weight 0.31 LBS 0.14 Kg
Belt Section SPECIAL
Effective Length 35.130 IN
Width 0.656 IN
Thickness 0.00 IN
Angle 26
Mark-Ia
PostPosted: Thu Jan 31, 2013 2:07 pm    Post subject: Re: Belt replacement and adjustment JD 110 1965 model Reply to specific post Reply with quote
Finger slipped one spot. Thanks for the correction Bob..
golfcartman
PostPosted: Thu Jan 31, 2013 5:41 pm    Post subject: Re: Belt replacement and adjustment JD 110 1965 model Reply to specific post Reply with quote
Thanks a bunch guys, I got the right primary belt ordered and will be in tomorrow. Thanks. Again
