Bad Day for my 8N
Goto page Previous  1, 2
souNdguy
PostPosted: Thu Jan 31, 2013 6:21 am    Post subject: Re: Bad Day for my 8N Reply to specific post Reply with quote
yep..it may show charged up and have voltage drop fast when loaded.
Hec In Omaha
PostPosted: Thu Jan 31, 2013 7:18 am    Post subject: Re: Bad Day for my 8N Reply to specific post Reply with quote
Hobo,
When I hit the starter button my amp meter barely moves. It moves more if I turn on the lights compared to when only the solenoid is clicking. I have new battery cables that are Size 1 gage. I installed them about 2 months ago. When I installed them I wire wheeled every connection to shiny metal. I am getting a solid 12.5 V measured at the positive batt connection at the solenoid. I don"t think its a connection although I will check. The starter worked perfectly that morning to start the tractor and then to move the dead tractor about 50 feet onto my drive. After that nothing. I will try the moving the Batt positive connection to the other side of the solenoid and see what that does.
Hec
gwo1973
PostPosted: Thu Jan 31, 2013 8:07 am    Post subject: Re: Bad Day for my 8N Reply to specific post Reply with quote
I have Electronic ignition on my 8N as well. It gets wet, dies. Nature of the beast. Dunno why or how moisture upsets it. Makes plowing snow difficult since I have to wait for the storm to be over instead of staying on top of it. Not sure if a side mount wouldn"t have the same issue or not.
Hobo,NC
PostPosted: Thu Jan 31, 2013 9:19 am    Post subject: Re: Bad Day for my 8N Reply to specific post Reply with quote
Hec In Omaha wrote:
(quoted from post at 19:18:16 01/31/13) Hobo,
Hec
Just as I thought that proves the amp meter useless unless the amp meters lubbers can tell you how that useless amp meter can help you on your no crank...
Try a voltmeter and report your findings... While not trying to crank and trying to crank... If voltage stays at 12.6 either way Google voltage drop testing...
Dell (WA)
PostPosted: Thu Jan 31, 2013 10:20 am    Post subject: Re: Bad Day for my 8N Reply to specific post Reply with quote
Hec.......Hobo's right, amp-meter don't tell you 'nuttin' about magic solid state electronic ignition. (its the way xstr ign is wired) Unfortunately, xstr ign either works or it don't and when it don't, its time to replace the $150 magic points. You doubt? Call Pertronix and complain. 4-nipple dizzy's don't like Pertronix modules. The module wiring don't like the cork water proofing gaskets. And sparkies don't like moisture inside the 4-nipple cap.
As fer using yer starter motor to move yer tractor outta the driveway, good thinking. Now yer starter drive is stuck in yer flywheel ring. Just loosen yer 2-LONG screws a little bitt and wobble yer starter motor and that should release the binding pressure. (remember to re-tighten) Using yer starter motor to move yer tractor should NOT burn yer starter motor up. (unless you ran it for 5-minutes) ........Dell, yer self-appointed sparkie-meister
L.B,
PostPosted: Thu Jan 31, 2013 3:21 pm    Post subject: Re: Bad Day for my 8N Reply to specific post Reply with quote
Moisture is a ign killer. If ya have cold moist air the 1st place to address starting or running problems is the cap and rotor as it gets condensation inside.Remove cap and take a hair dryer to the inside of the cap and rotor. Its not always the problem but its my starting point.
Hec In Omaha
PostPosted: Thu Jan 31, 2013 6:44 pm    Post subject: Re: Bad Day for my 8N Reply to specific post Reply with quote
Dell,
Thanks for the input. I haven't worked on it today. Too Darn cold outside. Its 5 degrees adn windy! I will work on it this weekend. Should be in the 30's to 40's. I am thinking I may have smoked the solenoid. I only cranked it for about 30 seconds at a time then waited a couple of mins and cranked her again. I was heading down a gentle slope so I would get the tractor rolling with the starter, then hold the clutch in till she stopped. I'll keep everyone posted. As for the ignition issues I am betting its my ignition switch. I will jump the switch and see what happens after I get the tractor cranking.
Hec
Page 2 of 2
