Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
farmall 560 head bolts and leaky head gasket
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling
bard
PostPosted: Wed Jan 30, 2013 12:32 pm    Post subject: farmall 560 head bolts and leaky head gasket Reply to specific post Reply with quote
I just has a 560 completely rebuilt by a very reputable machine shop in the area. It was put together basically for stock classes. Its a stock kit, head and block have both had fourty thousandths each taken off. The cam was redone to match the engine and he does a very good job making heads flow and this was also done along with new crank and oil pump. He has put two different head gaskets in it and cannot get it to stop leaking. I am perfectly confident with him that the block and head are true, like I said its a very reputable place in my area. The one and only thing that wasn't replaced was the head bolts so I guess thats the next step unless someone can give me a better suggestion. Is there anywhere around other than a dealer to get new head bolts and good quality ones at that? Thanks
Dieseltech
PostPosted: Wed Jan 30, 2013 1:19 pm    Post subject: Re: farmall 560 head bolts and leaky head gasket Reply to specific post Reply with quote
With both head and block milled are bolts bottoming out before head is tight? And retorqued when hot? Just a thought.
Gary Baker
PostPosted: Wed Jan 30, 2013 4:33 pm    Post subject: Re: farmall 560 head bolts and leaky head gasket Reply to specific post Reply with quote
If he's using a Felpro gasket it will never hold. Go to Case IH dealer and get stock gasket from them.
bard
PostPosted: Wed Jan 30, 2013 6:11 pm    Post subject: Re: farmall 560 head bolts and leaky head gasket Reply to specific post Reply with quote
The first gasket was a copper gasket that came with the engine kit that I got from Murphys, the second was a Felpro gasket. Thats whats in it now, after reading the reply from Gary I guess its coming back off too.
north puller
PostPosted: Wed Jan 30, 2013 6:42 pm    Post subject: Re: farmall 560 head bolts and leaky head gasket Reply to specific post Reply with quote
Copper gaskets can be tricky, and as Gary said, felpro are junk.
Get the case IH one and spray both sides with copper coat gasket spray. Let it tack up then install.
Waarm it up with RPM but no load till hot then re-torque. Warm up and re-torque once more. Now you should be good to go. Throw it at the dyno and break it in.
Gary Baker
PostPosted: Wed Jan 30, 2013 7:00 pm    Post subject: Re: farmall 560 head bolts and leaky head gasket Reply to specific post Reply with quote
Felpro gaskets last about 1 hour for me. The company should be ashamed. They probably dont test their headgaskets. Ive talked to the company rep and they dont seem to care
rustred
PostPosted: Thu Jan 31, 2013 5:32 am    Post subject: Re: farmall 560 head bolts and leaky head gasket Reply to specific post Reply with quote
with .080 removed, might not get any gasket to seal this already problematic area on these engines.
dboll
PostPosted: Thu Jan 31, 2013 5:49 am    Post subject: Re: farmall 560 head bolts and leaky head gasket Reply to specific post Reply with quote
If you didn't use some good head studs from ARP or similar you need to get some.
doorman
PostPosted: Thu Jan 31, 2013 6:31 pm    Post subject: Re: farmall 560 head bolts and leaky head gasket Reply to specific post Reply with quote
Huh, I just pulled the head on my 560 motor and it has an IH part# and also a Felpro marking.
Old engine, completely stock. no sign of any leakage.
Brad Vinkemeier
PostPosted: Fri Feb 01, 2013 11:23 pm    Post subject: Re: farmall 560 head bolts and leaky head gasket Reply to specific post Reply with quote
What size head bolts are used on a 560 is it a gas or diesel I know some people that had this problem before with the 282 diesels in the 560 and the changed out the head with a head from a 706 with the 282 diesel which used one size bigger head bolts and drilled out and retaped the block for the bigger head bolts and make sure the bolts arnt bottoming out and use good head bolts from case in or arp my other question is are u running a turbo that can have some impact on this problem depending on how much boost pressure it has although I have run into the same problem on our 706 diesel with pump opened up a bit and the timeing advanced a lil running 3100 rpms on the dyno and put out 130hp and it would start to weep coolant out from the very back side of the head
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
