Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
TO 20 oil pressure
Post new topic    Yesterday's Tractors Forum Index -> Harry Ferguson
37chief
PostPosted: Wed Jan 30, 2013 7:51 pm    Post subject: TO 20 oil pressure Reply to specific post Reply with quote
My TO 20 idles around 15, and motor running at working speed it is 20 lbs. Think the oil pressure is within limits? Thanks Stan
maxwell99
PostPosted: Wed Jan 30, 2013 9:16 pm    Post subject: Re: TO 20 oil pressure Reply to specific post Reply with quote
Might try a bottle of Lucas oil stabilizer, that material would help increase the old pressure on my to35 when hot. At the time I was using 10w40 weight oil.
Currently I run shell rotella 15w40 oil. The reason
I changed oil weights: I determined that the shell oil has the additive zinc and the car/truck oils do not have zinc.
The old engines need the zinc additive for long life, plus
with 15w40 the oil pressure stays up in the normal range when the motor is at operating temp at idle.
Bruce(OR)
PostPosted: Wed Jan 30, 2013 9:39 pm    Post subject: Re: TO 20 oil pressure Reply to specific post Reply with quote
When I did the wife's TP-20 the OP was around 35 after rebuild hot or cold. I also went down to the hyd shop and picked up two rubber oil pick up line seals for about $3 and replaced those along with rebuilding the oil pump.
I also took the oil gauge down to an instrument repair shop and had it tested for accuracy. It was off by 2 PSI.
The zinc oil additive is wonderful for flat tappet cams. Heavy duty rated oil leaves a film behind that energy conserving oil does not.
Now if your oil pressure on a used motor is 15 at warm idle and 20 under speed, I would suspect it has a good amount of life left in it.
Jerry/MT
PostPosted: Wed Jan 30, 2013 9:59 pm    Post subject: Re: TO 20 oil pressure Reply to specific post Reply with quote
Specs are 25-30 psig new and lower limit is 15 psig at 400 rpm idle speed and the engine at operating temperature.
You are exhibiting signs of a worn oil pump, and/or stuck open relief valve an/or worn main bearings.
Sounds like you are just barely within limits at idle.
purecty
PostPosted: Thu Jan 31, 2013 1:56 am    Post subject: Re: TO 20 oil pressure Reply to specific post Reply with quote
the plug that goers in the motor of the oil gauge line. is it a special plug? mine has a little round hole in it. i bought 2 new ones but neither one looked like the one that came out of it. they were wide open holes. the guy at the tractor repair shop said the open ones wouldnt work,
bill
2tractors
PostPosted: Thu Jan 31, 2013 5:20 am    Post subject: Re: TO 20 oil pressure Reply to specific post Reply with quote
The brass fitting that goes into the block is made for a flared fitting which is what the hard line has on the end of it.
purecty
PostPosted: Thu Jan 31, 2013 7:11 am    Post subject: Re: TO 20 oil pressure Reply to specific post Reply with quote
im just saying that the 2 3/8 sizes i bought are not like the one that came out of the block. the ones i bought was a straight hole through it. the one that came out had like a small hole in it to slow the flow down. thanks
bill
purecty
PostPosted: Thu Jan 31, 2013 7:41 am    Post subject: Re: TO 20 oil pressure Reply to specific post Reply with quote
i was just wondering what the difference is?
bobs old iron
PostPosted: Thu Jan 31, 2013 8:40 am    Post subject: Re: TO 20 oil pressure Reply to specific post Reply with quote
cheif- i have about the same readings on my to-20, when i was in the parade for over an-hour, running at same speed, except when parade comes to stop, oil pressure would drop a little, also, i have never changed oil since i've owned it for over 5-years.. that's the next thing when weather gets warmer, this year,,lol
