Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
582 speicial
Post new topic    Yesterday's Tractors Forum Index -> Garden Tractors
jdv
PostPosted: Wed Jan 30, 2013 7:55 pm    Post subject: 582 speicial Reply to specific post Reply with quote
Looking for a hood and side shields for my
international 582 special. It has an amp gauge but
I havent been able to get it to charge, can't find
a gen on it. It has a 16hp briggs, is this a
repower?
R Bedell
PostPosted: Thu Jan 31, 2013 3:29 am    Post subject: Re: 582 speicial Reply to specific post Reply with quote
jdv:
NO...the B&S 16HP was OEM.
You could try here in looking for your parts..... Parts
joe csuti
PostPosted: Thu Jan 31, 2013 4:30 am    Post subject: Re: 582 speicial Reply to specific post Reply with quote
As r bedell said,orig eng a briggs 16hp,if you check id tag on eng will probably be mod# 401417(180 deg opposed twin-L head)if it is this eng,same has an alternator not a generator,stator for alt is located under flywheel.
Looking at several wiring diag online for tractor output from alt is one wire with an inline diode(unregulated output)this mod eng used several different amperage output alt stators depending on how eng ordered from briggs.
The best thing you can do to help yourself is goto ebay & type briggs twin L head manual in search & buy the paper/cd version,in it will be info on how to id charging system & test/troubleshoot ON ENG charging system,while on ebay also do a search for cub cadet 582,go thru listings,you might get lucky & find parts you're looking for.
Do a goggle search for cub cadet 582+wiring diagram,from row of posted diag,click on left drawing in row,check that sn of tractor in listed range,if it is enlarge diagram/print,The not charging issue could be an on eng problem,wiring harness problem on tractor,bad ign sw,bad ammeter or loose/broken connections,the 1st thing you have to do is determine if charging system on eng working & then take it from as to rest of elect system on tractor.
Greenday
PostPosted: Thu Jan 31, 2013 4:40 am    Post subject: Re: 582 speicial Reply to specific post Reply with quote
Probably has the alternator under the flywheel
El Toro
PostPosted: Thu Jan 31, 2013 6:03 am    Post subject: Re: 582 speicial Reply to specific post Reply with quote
Look for a rectifier/regulator and use a volt meter to see if you have about 30 volts AC voltage from your stator. Your rectifier may be defective if you have ac voltage. Before replacing the rectifier I would clean all the wiring connections at the rectifier. I found this problem on a JD 140 tractor. Hal
