| Author |
Message |
Tom Beddard ENC Regular
Posted: Thu Jan 31, 2013 9:16 am Post subject: 12V roundcan conversion - no fire! |
46 2N front mount converted to 12V. I drilled an old 6V squarecan & that went well- all connections have continuity. I bought NAPA IC 14SB coil, installed it, bypassed all resistors and get no spark- Put 6V coil back on with all resistors and it fired right up so I know points & all are fine. Then put back 12V round & no go. What should I try next? |
| Back to top |
souNdguy Tractor Guru
Posted: Thu Jan 31, 2013 9:23 am Post subject: Re: 12V roundcan conversion - no fire! |
that means you have concluded it is a wireing problem in your conversion.
double check the following:
wire from key goes to round coil primary, and then fromt the other primary terminal, it goes out and to the connection on the coil that uses the pig tail.
the 2ndary of the round goes to the connection int he square with the flat tab. |
| Back to top |
Posted: Thu Jan 31, 2013 10:08 am Post subject: Re: 12V roundcan conversion - no fire! |
Thanks for reply. I'll double check but that's the way it's wired- I must have something wrong. I'll post back later today. Thanks!! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
