| Author |
Message |
71ford100 Long Time User
Posted: Fri Feb 01, 2013 9:13 am Post subject: Case CC with a Waukesha and a single front wheel. |
Went to an old junkyard and this Case was in there. The serial tag was gone the block is cracked otherwise it is pretty complete. The owner said we would dell tractors out whole.
| Back to top |
L.C.Gray Regular
Posted: Fri Feb 01, 2013 9:35 am Post subject: Re: Case CC with a Waukesha and a single front wheel. |
That's an RC, smaller than a CC. Looks like a '37 or '38 model. |
| Back to top |
Harvey 2 Regular
Posted: Fri Feb 01, 2013 9:36 am Post subject: Re: Case CC with a Waukesha and a single front wheel. |
Are you sure it isn't and RC instead of a CC ?
I had an RC several years ago that looked a lot like it. |
| Back to top |
Bud Tierney Regular
Posted: Fri Feb 01, 2013 9:52 am Post subject: Re: Case CC with a Waukesha and a single front wheel. |
Early Rs came with Wauk FK or FKJ (35-6??) later replaced by FC, sometimes shown as the FC9T (the "9T" being the works code for accessories etc (ign, carb etc)... |
| Back to top |
C. Amick Long Time User
Joined: 05 Mar 2009 Posts: 1147 Location: Pulaski, VA
Posted: Fri Feb 01, 2013 12:24 pm Post subject: Re: Case CC with a Waukesha and a single front wheel. |
Did the hand clutch push forward to engage on an RC like it did on the SC? |
| Back to top |
Racine Regular
Posted: Fri Feb 01, 2013 12:47 pm Post subject: Re: Case CC with a Waukesha and a single front wheel. |
C.Amick
I note with interest you note regarding the clutch lever movement on a model "RC" tractor.
No the clutch lever on the model's "L", " C ", early " D " and " RC" tractors are ALL mounted on the right hand side of the transmission, and YES they are all puled back to engage, and pushed forward to disengage. Then with the Falmbeau Red tractors, the levers were mounted on thje left side of the transmission - these were pushed forward to engage and pulled back to disengage the clutch. I am sure that a Waukesha engine would NOT fit up to a model "CC" or "C" tractor Transmissin housing. Hope that this clears up your query.
Regards
Alan T. Lewis
Christchurch
NEW ZEALAND |
| Back to top |
oleclint Long Time User
Posted: Fri Feb 01, 2013 1:02 pm Post subject: Re: Case CC with a Waukesha and a single front wheel. |
Look at the rear axel on this R C. Then look at a rear axel on a CC , you will see that they are not even close to beig the same. clint |
| Back to top |
casenut1 Tractor Expert
Posted: Fri Feb 01, 2013 2:07 pm Post subject: Re: Case CC with a Waukesha and a single front wheel. |
Afraid i have to disagree with you.i have a 36 and a 38 RC and you push forward to engage the clutch. when you pull back that engages the belt pulley brake pad on the pulley. |
| Back to top |
Posted: Fri Feb 01, 2013 2:08 pm Post subject: Re: Case CC with a Waukesha and a single front wheel. |
where is this located at. |
| Back to top |
dboll Guest
Posted: Fri Feb 01, 2013 3:14 pm Post subject: Re: Case CC with a Waukesha and a single front wheel. |
it'a an RC, for the money it will take to fix you can buy a runner but it would be worth something as a parts donor |
| Back to top |
JimEvans Regular
Posted: Fri Feb 01, 2013 5:00 pm Post subject: Re: Case CC with a Waukesha and a single front wheel. |
A single front on a chicken roost RC is fairly rare. At least I haven't seen any. It is probably more rare than dual front wheels on a over-the-top RC. And, yes, you push the clutch lever forward to engage. |
| Back to top |
dboll Guest
Posted: Sat Feb 02, 2013 7:07 am Post subject: Re: Case CC with a Waukesha and a single front wheel. |
Bendover, Utah |
| Back to top |
Posted: Sun Feb 03, 2013 10:26 am Post subject: Re: Case CC with a Waukesha and a single front wheel. |
The tractor is between Loveland and Greeley Colorado. |
| Back to top |
