| Author |
Message |
LonM Regular
Posted: Fri Feb 01, 2013 1:52 pm Post subject: Warming up a cold tractor |
We run two 3020 diesels every day for feeding cattle, both have tank heaters for the engine and both have synchro transmissions. They start fine, but the hydraulics really whine and they steer hard when it is this cold out (-20 F). Today for one tractor I put two hydraulic tips on one hose and plugged each end into the SCV and just let it circulate oil through the system while I loaded the feed wagon. This seems to help. Does anyone have any other "tricks" to get that hydraulic system warmed up more efficiently (outside of a heated shop)? Thanks for any discussion!
LonM |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13176 Location: Coyote Flats,Tx
Posted: Fri Feb 01, 2013 2:05 pm Post subject: Re: Warming up a cold tractor |
Back when I worked as service manager for a JD dealer circulating the oil with the scv with a hose with a male coupler tip on each end to get hyd oil warm so a leak would show up better is the way I did it also. Doesn't take a long time in warm weather for oil to get hot. |
| Back to top |
chevytaHOE5674 Long Time User
Joined: 19 Mar 2009 Posts: 1400 Location: Western UP, Mi
Posted: Fri Feb 01, 2013 2:28 pm Post subject: Re: Warming up a cold tractor |
I have a magnetic heater that I stick on the sump of my hay feeding tractor that I plug into the same timer as the block heater. Really helps on the cold days. |
| Back to top |
Fred2 New User
Posted: Fri Feb 01, 2013 7:52 pm Post subject: Re: Warming up a cold tractor |
Deere made a heater that screwed into the transmission case for that need to check with your dealer |
| Back to top |
Tx Jim Tractor Guru
Posted: Sat Feb 02, 2013 4:15 am Post subject: Re: Warming up a cold tractor |
| Fred2 wrote: | | (quoted from post at 22:52:45 02/01/13) Deere made a heater that screwed into the transmission case for that need to check with your dealer |
The part AR98518 is no longer available. Contact your local John Deere dealer for other options.
| Back to top |
larryanderson Long Time User
Posted: Sat Feb 02, 2013 4:18 am Post subject: Re: Warming up a cold tractor |
On our new 6170 JD loader tractor the cold weather package heats engine ,trans and water which makes it start easy plus the hydraulics work easier.The only problem is when I first got it it would trip the circuit breakers but they fixed it.So I am sure it must use more amperage than with just one function.Plugging them in an hour or more is a lot easier on them but the hydraulic oil at 20 below can be real slow for a while.The oil in the loader cylinders takes a while to get it into system. |
| Back to top |
Gundoctor Regular
Posted: Sat Feb 02, 2013 5:37 am Post subject: Re: Warming up a cold tractor |
How about SYNTHETIC Hydraulic Oil. I have never use it but we keep getting ads for Amsoil. Would this be the answer?? Would this help???
Has anyone put this in your tractor???
I would like to know!!!!! It was -30 here last week!!
David Pidgeon
New Haven, Vermont |
| Back to top |
48farmall Regular
Posted: Sat Feb 02, 2013 6:58 am Post subject: Re: Warming up a cold tractor |
Just an idea-
Would something like this work for you? I'm not sure where/if there's a place to put it on your particular tractor.
Untitled URL Link
| Back to top |
LonM Regular
Posted: Sat Feb 02, 2013 8:09 am Post subject: Re: Warming up a cold tractor |
Thanks everyone for the replies. I don't know if Hy-Gard or its equivelant is available in synthetic or not but I'll look into it. External heat pads look like a good option...
LonM |
| Back to top |
tomstractorsandtoys1 Long Time User
Posted: Sat Feb 02, 2013 8:57 am Post subject: Re: Warming up a cold tractor |
We have the same issue on our 3020 that is used on our tmr mixer.The hose idea is the best I have found. We tried a dipstick heater but it did not work. |
| Back to top |
Tx Jim Tractor Guru
Posted: Sat Feb 02, 2013 9:14 am Post subject: Re: Warming up a cold tractor |
You might try Low-Viscosity Hy-Gard™ |
| Back to top |
Cooney Minnie Regular
Posted: Sat Feb 02, 2013 12:05 pm Post subject: Re: Warming up a cold tractor |
Deere recommended the hose trick to warm the oil before using a hydrapush spreader in the dead of winter.... |
| Back to top |
Johndeere39h New User
Posted: Sat Feb 02, 2013 2:51 pm Post subject: Re: Warming up a cold tractor |
That part AR98518 there is one on eBay right now for 21.99 with free shipping just did a search for it by that part number if that helps any?
Jeff |
| Back to top |
Fred Gross New User
Posted: Sat Feb 02, 2013 3:36 pm Post subject: Re: Warming up a cold tractor |
Regarding the Amsoil synthetic hydraulic oil. I run it in my JD 2210 CUT. The manual calls for either low or hi viscosity hygard depending on the temps. When i did my 200 hour oil change I switched over to Amsoil ATH and have been using it ever since. The 2210's power steering and hydraulics work great even at -10 or below and I notice no difference in performance other then it works better when it's cold. If I was using a tractor every day in subzero weather I would definitely run synthetics throughout. |
| Back to top |
