| Author |
Message |
d13still Guest
Posted: Sat Feb 02, 2013 7:54 am Post subject: B oil seal retainer bolts and metal tabs |
Finally getting the engine back together, and darned if I can find the rear oil seal retainer bolts and those pesky metal tabs. Bolts are easy enough to replace, but wondering if I can do without the tabs? I know lock washers are out unless I put round washers under them, due to the aluminum housing. A little dab of Locktite Red should prevent loosening and seal the bolts to the block, and the retainer face is fully gasketed to the block around the bolts. Any thoughts? |
| Back to top |
steve(ill) Tractor Expert
Posted: Sat Feb 02, 2013 7:59 pm Post subject: Re: B oil seal retainer bolts and metal tabs |
loctite should work o.k.... you could alsobuy bolts with cross drilled heads and wire them.. i would think McMaster Carr and others sell the sheet metal locks if you want that. |
| Back to top |
Dick L Tractor Guru
Posted: Sun Feb 03, 2013 5:16 am Post subject: Re: B oil seal retainer bolts and metal tabs |
Some of the B"s and C"s had bolts that were drilled and wired rather than having the tabs. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
