| Author |
Message |
Dave OBrien New User
Posted: Sat Feb 02, 2013 5:24 pm Post subject: 3-pt. Hitch on a B or C. |
Has anyone on here done this? If so, Was it worth the effort/cost? How did it work out for you? |
| Back to top |
Bob Bancroft Tractor Expert
Posted: Sat Feb 02, 2013 5:56 pm Post subject: Re: 3-pt. Hitch on a B or C. |
I bought the cheapest one I could find several years ago. After several repairs and rebuilds, I got it right. Believe it or not, I hauled around a light 5' bush hog for several years. That's not necessary any more. But I now have a light landscape rake which works great on it. And, I just switched my belly mower from my B to the C, and used cables and pulleys off the three point to raise the mower. I have some chains to hold the mower up so I can use the rake on the three point while the mower is still attached. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50434 Location: Lake of the Ozarks area of MO
Posted: Sat Feb 02, 2013 6:00 pm Post subject: Re: 3-pt. Hitch on a B or C. |
I built one years ago on my C and it does ok. Used the plow lift to then make it into a 3 point |
| Back to top |
steve(ill) Tractor Expert
Posted: Sat Feb 02, 2013 7:53 pm Post subject: Re: 3-pt. Hitch on a B or C. |
bought two lower arms for a 9N at the farm store. Built a frame between the final drive 5/8 inch bolts and put both arms onto this frame. Use the rock shaft upper arms to raise the 9N arms. |
| Back to top |
RalphWD45 Long Time User
Posted: Sat Feb 02, 2013 11:21 pm Post subject: Re: 3-pt. Hitch on a B or C. |
I got a 52 B that had a cheap aftermarket 3 pt on it, that was rated at 250 lbs.That rating seemed useless to me , so I bought 2 ford arms, replaced the rockshaft, with a larger diameter shaft, replaced the cylinder, with a 3"x8" cylinder, that was rated for 3000 psi. In later yrs I put a front pump on it, and went to double acting cylinders, and a control valve on the fender. I now haul large round bales, out of the barn, and feed cows with a 3pt hay spear. WARNING use enough weight on the front! I carry 200 lbs of steel weight, and both front tires are loaded with calcium. |
| Back to top |
Posted: Sun Feb 03, 2013 6:21 am Post subject: Re: 3-pt. Hitch on a B or C. |
yes, i have a couple hundred pounds of weight on the front of mine also. |
| Back to top |
dej(Jed) Tractor Expert
Posted: Mon Feb 04, 2013 5:12 am Post subject: Re: 3-pt. Hitch on a B or C. |
Those tractors don't have much front end weight as it is. Hanging an implement on teh back could get dicey. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
