Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
8N Ice in crankcase breather cap breather tube
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
Dale J. Swanson
PostPosted: Sun Feb 03, 2013 11:41 am    Post subject: 8N Ice in crankcase breather cap breather tube Reply to specific post Reply with quote
Thanks for your comments on my changing from 30W oil to 10W 40. While plowing the oil pressure read around 40 and while idling around 15. Is this acceptable? The only thing that I have a question about is ice in the crankcase breather cap and the breather tube this morning. Is this common or is this something to be concerned about? Also if I put 5W 30 oil in it would it be better for my engine?
R Geiger
PostPosted: Sun Feb 03, 2013 11:50 am    Post subject: Re: 8N Ice in crankcase breather cap breather tube Reply to specific post Reply with quote
Dale J. Swanson wrote:
(quoted from post at 04:41:19 02/04/13) Thanks for your comments on my changing from 30W oil to 10W 40. While plowing the oil pressure read around 40 and while idling around 15. Is this acceptable? The only thing that I have a question about is ice in the crankcase breather cap and the breather tube this morning. Is this common or is this something to be concerned about? Also if I put 5W 30 oil in it would it be better for my engine?
Oil pressure are good. the ice in the breather is caused by water vapor condensing and not running it long enough to burn off the moisture.
old
PostPosted: Sun Feb 03, 2013 12:35 pm    Post subject: Re: 8N Ice in crankcase breather cap breather tube Reply to specific post Reply with quote
I would stay with the 10W40 since you have good pressure with it and may not if you drop down to a thinner oil. As for the ice well that is condensation from the cold engine so normal as long as you run it enough to melt it off and steam it away
duey
PostPosted: Sun Feb 03, 2013 12:39 pm    Post subject: Re: 8N Ice in crankcase breather cap breather tube Reply to specific post Reply with quote
One of the best things for ANY engine is a good thermostat... be sure your engine warms up properly....
Colin King
PostPosted: Sun Feb 03, 2013 2:42 pm    Post subject: Re: 8N Ice in crankcase breather cap breather tube Reply to specific post Reply with quote
Your oil pressure is great.
In addition to what the others have said about a thermostat, you may want to service the breather cap. They can and do get plugged up with oil and combustion sludge after 60+ years of service. Test it so see if air passes through it.
If no air passes through it, clean the breather element with a degreaser of your choice. I soak mine overnight in whatever cleaning solvent I have at hand - usually old diesel or mineral spirits.
Colin, MN
Ultradog MN
PostPosted: Mon Feb 04, 2013 3:44 am    Post subject: Re: 8N Ice in crankcase breather cap breather tube Reply to specific post Reply with quote
There are a lot of questions here about water or milky looking stuff under the oil fill/breather cap. Usually it is caused by condensation.
That is good advice below about making sure you have a good working thermostat.
But even with a good thermostat it's still important to get the tractor out and work the snot out of it regularly. That will make the condensation evaporate in not only the engine but the tranny and rear end too.
Dale J. Swanson
PostPosted: Thu Feb 07, 2013 4:39 pm    Post subject: Re: 8N Ice in crankcase breather cap breather tube Reply to specific post Reply with quote
My transmission fluid had a brownish look to it so I went to Tractor Supply and bought some 90W oil that is recommended for older Ford Tractors from 1939 to 1952. My tractor is a 1952 8n. After draining my old oil out I started replacing it with the new, I noticed quite a difference in the thickness of the new oil. Now it seems to me it would take forever to warm this oil up before I could begin to plow. I only put in 4 Gallons because I wanted to check with the experts on the Forum to see if their is a possible way of thinning it out. Has anyone heared of adding mineral spirits as a thinner?
I only use my tractor in the winter to plow when the temperatures are normally below freezing here in Michigan. Would this thick oil slow down the response time when lowering & raising the plow?
