| Author |
Message |
big Mo Guest
Posted: Sun Feb 03, 2013 6:11 pm Post subject: pulling motor |
How big of a motor can you make out of a 670 block 800 heads |
| Back to top |
Jeff Gravert Regular
Posted: Mon Feb 04, 2013 4:43 am Post subject: Re: pulling motor |
How big is directly related to the depth of your pockets. 900 cid is pretty big. Jeff |
| Back to top |
6pack Regular
Posted: Mon Feb 04, 2013 5:42 am Post subject: Re: pulling motor |
I am gathering parts for a 5.50" bore X 7.625" stroke, Jeff G. Is putting the 800 jugs on a 670 crank case for me. Real good guy to talk to.
I would say this is an average build... Some smaller and some a lot bigger!!
Rick |
| Back to top |
brentp4455 Regular
Posted: Mon Feb 04, 2013 9:17 am Post subject: Re: pulling motor |
is it true there are recast jugs being made? how big
can they go? |
| Back to top |
Shawn W Regular
Posted: Mon Feb 04, 2013 3:13 pm Post subject: Re: pulling motor |
go look on the pulling page and scroll back a few pages, i asked on there couple weeks ago and the guy that makes them put his number and name up there. |
| Back to top |
big Mo Guest
Posted: Tue Feb 05, 2013 12:10 am Post subject: Re: pulling motor |
Jeff what's the bore and stroke for 900. Can you build one 1000. Looking to beat up on some 460 with red diamond motors. |
| Back to top |
MMMMMMMMMMMM Guest
Posted: Tue Feb 05, 2013 4:35 am Post subject: Re: pulling motor |
MM heads will not flow enough to feed a 900 cid 4 cylinder motor. 1000 cid is a total waste of money unlees your main goal is to brag on how big your motor is. |
| Back to top |
6pack Regular
Posted: Tue Feb 05, 2013 2:20 pm Post subject: Re: pulling motor |
If you are looking for a crank, I have one 7.625" I have not decided if I am gonna use it or not.... I might stay at 7.00-7.25...
It was welded by Jeff @ Stamm Equipment, and never used. Now for the bad news... It will need to be re ground as it was set up for U rods which will not work!!! Would have to do a custom rod... Give me an email address if interested, can send some pics too... This crank cost $2500 originally! |
| Back to top |
Posted: Tue Feb 05, 2013 8:28 pm Post subject: Re: pulling motor |
6.125 by 7.75 makes 913 cid. 800 parts are the only possible way to make that combo work. I have been itching to make one of these and if you got the money, I've got the time. Even with these inefficient old bastards taking around three cubes to make a horsepower that is still a pretty good ride. Past that a person needs to be building a LSS or LLSS. |
| Back to top |
newby puller New User
Posted: Tue Feb 05, 2013 9:37 pm Post subject: Re: pulling motor |
I have a set a 403 jugs bore to 5.5 sleeved and hard blocked never been installed yet anyway |
| Back to top |
PullerMMU Guest
Posted: Wed Feb 06, 2013 3:59 am Post subject: Re: pulling motor |
$2500 for that crank? Sounds like you got screwed.
I had one welded up and turned for about half that much. |
| Back to top |
6pack Regular
Posted: Wed Feb 06, 2013 5:59 am Post subject: Re: pulling motor |
MMU where can you get a crank stroked 1.625" for $1200? Is it still together?
Is it a backyard weld job? Bobby Hinton told me about a hack shop that are just welding blocks on to the journals and grinding them down and out the door they go! They do not last long
I did not have this crank done... It was another puller that had it done never put it together and lost interest, his loss my gain!!
I do know that around my area, guys are getting over $100 for every 0.100" of stroke added, 1 shop will not even quote it, it is a flat rate $80 until it is done... |
| Back to top |
PullerMMU Guest
Posted: Wed Feb 06, 2013 6:22 am Post subject: Re: pulling motor |
Hapco
Terre Haute, IN
812-232-2550
You got screwed. |
| Back to top |
RnRPerformance New User
Posted: Wed Feb 06, 2013 10:57 am Post subject: Re: pulling motor |
6Pack I am interested in the crank if it's still available. Send
me an email. Thanks.
Ryan |
| Back to top |
6pack Regular
| Back to top |
