| Author |
Message |
zstith Guest
Posted: Mon Feb 04, 2013 9:49 am Post subject: Farmall Super C Distributor bushing lubrication |
I have a Farmall Super C that I am rebuilding. It is the C123 engine. I have completely gone through the motor. For some reason I am not getting any oil up to the distributor bushing that is pressed into the block. I can"t figure this out. I have plenty of oil pressure and the oil hole is lined up and open, it"s just not getting to this bushing. Has anyone else had a problem similar to this? Any help would be appreciated. Thanks! |
| Back to top |
gene bender Tractor Guru
Posted: Tue Feb 05, 2013 8:46 pm Post subject: Re: Farmall Super C Distributor bushing lubrication |
Mite need to remove the drive assy by pulling the gov housing off then removing the gear assy and using compressed air blow in the lube hole to clear what mite be blocking the passage. |
| Back to top |
zstith Guest
Posted: Wed Feb 06, 2013 11:55 am Post subject: Re: Farmall Super C Distributor bushing lubrication |
I'll give it a shot. Thanks! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
