| Author |
Message |
F4RM@11 Regular
Posted: Mon Feb 04, 2013 10:57 am Post subject: Recommended Gasket Material |
What type and thickness of gasket material do you suggest for the rear axle carrier caps and PTO? What about suggestions on felt for the rear axle carrier caps?
GASKET, rear axle carrier cap
GASKET, power take-off oil seal retainer
WASHER, felt, rear axle
1953 Stage II Super M |
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Mon Feb 04, 2013 12:25 pm Post subject: Re: Recommended Gasket Material |
Don't know about the felt. I got gasket paper from my local Ace
hardware and also from the local independent auto parts store. I
just got the sheets that were big enough to make the gasket out of
one piece, I do not think the thickness is critical on those
applications.
Zach |
| Back to top |
Nebraska Kirk Tractor Expert
Posted: Mon Feb 04, 2013 2:02 pm Post subject: Re: Recommended Gasket Material |
The felt you can get from your local CaseIH dealer.
As far as gasket material goes, 1/32" or 1/64" thickness, either will work just fine. |
| Back to top |
David G Tractor Guru
Posted: Mon Feb 04, 2013 2:50 pm Post subject: Re: Recommended Gasket Material |
I just bought mine from CIH, looked real nice. |
| Back to top |
CNKS Tractor Guru
Posted: Mon Feb 04, 2013 6:45 pm Post subject: Re: Recommended Gasket Material |
I don't make gaskets as they are cheap enough from CaseIH, and I can never get the right thickness anyway. Not sure you can still get the felt, if not use the old one if it is still any good. |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5362 Location: SE Wisconsin
Posted: Tue Feb 05, 2013 4:21 am Post subject: Re: Recommended Gasket Material |
| CNKS wrote: | | (quoted from post at 19:45:09 02/04/13) I don't make gaskets as they are cheap enough from CaseIH, and I can never get the right thickness anyway. Not sure you can still get the felt, if not use the old one if it is still any good. |
90% of the time that is what I do. When you start working on the MD sometimes you need to take charge and make your own. That or there is that one simple gasket that you forgot to order and you want to just finish.  |
| Back to top |
CNKS Tractor Guru
Posted: Tue Feb 05, 2013 8:50 am Post subject: Re: Recommended Gasket Material |
The only gasket not available for the SH and SM (can't speak for the MD) is the one under the belt pulley. I make an occasional one, and generally order gaskets as I disassemble. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
