| Author |
Message |
Paul Shuler Regular
Posted: Mon Feb 04, 2013 11:40 am Post subject: Need advise to get bearing out |
I am in the process of replacing the inner and outer axel seals in a 1950 Farmall C. The inner seal {one closest to the bull gear side} has the bearing between me and the seal I need to get to. Tell me the best way to remove this bearing so I dont do something stupid.....again. Amazing how stinky and nasty this rear end oil is.
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Mon Feb 04, 2013 12:24 pm Post subject: Re: Need advise to get bearing out |
It looks just like the H and 300 axles I have had apart, only smaller. Now that you have all of the retainers off you should be able to pick it up by the 'ears' of the housing and bump the end of the axle on a concrete floor and it will pop right out. This may not apply for Cs but it sure does look the same.
Zach |
| Back to top |
Dennis K (WA) Regular
Joined: 05 Mar 2009 Posts: 263 Location: Ridgefield, Wa.
Hi Paul,
Put a block of wood on the floor so you don't damage the splines, stand it up vertically with bull gear end down. Pick it up a bit and drop it on the splined end and the shaft with outer bearing will slide out.
Inside the housing will be full of grease from bearing being greased for many years. Once the shaft is out you can go down through the housing and drive out the other bearing and then the seal.
good luck
Dennis |
| Back to top |
retired farmer Long Time User
Posted: Mon Feb 04, 2013 12:26 pm Post subject: Re: Need advise to get bearing out |
Get a block of wood and a big sledge hammer and tap on the outer end of the shaft first. If it is made the way I think it is the inner bearing should drive out with the shaft so you will be able to get to the seal. |
| Back to top |
El Toro Tractor Guru
Can that greasy housing be removed from the shaft in the center? If it can then you would have access to the bearing. Hal |
| Back to top |
Paul Shuler Regular
Posted: Mon Feb 04, 2013 4:18 pm Post subject: Re: Need advise to get bearing out |
And what is the best way to put the bearings back in? Will i
need a press or can i tap them back into place after the new
seal goes in? |
| Back to top |
Posted: Mon Feb 04, 2013 5:13 pm Post subject: Re: Need advise to get bearing out |
They will tap back in with a mallet or a hammer and a block of wood.
Zach |
| Back to top |
Posted: Mon Feb 04, 2013 6:41 pm Post subject: Re: Need advise to get bearing out |
So, you must have gotten them out, right?
I found it a help to file a chamfer on the end of the splines to aid in starting the bull gear back on.
Dennis |
| Back to top |
PaulW_NJ Long Time User
Joined: 05 Apr 2005 Posts: 608 Location: Morristown, NJ
Posted: Tue Feb 05, 2013 5:09 am Post subject: Re: Need advise to get bearing out |
Above are some photos of my rebuild of my 240, which I believe has the same rear axle design as the Super C. As everyone has said, the bearing should tap off . . . yours must be up against a burr on the shaft. A gear puller may help ease it off, but I'd really try to find whatever imperfection along the splined end is causing the hang up before I apply too much lateral force on that bearing. You'll need a smooth slip for reinstalling the entire axle, so best to touch up the splines first. Good luck.
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
