| Author |
Message |
JDJACK Long Time User
Posted: Mon Feb 04, 2013 4:32 pm Post subject: Bench grinder questions |
I am looking at making a purchase on a bench grinder.
There is alot of junk out there from $50-$180.00.
I am looking at a baldor 6 inch grinder 1/4 hp 1800 rpms, verses the common 3600 rpm's.
Are the slower 1800 rpms ons better?
I heard they don't burn the metal as much, and dont stall out.
Price is around #450.00 and should last my lifetime, think they are still made in the usa. |
| Back to top |
retired farmer Long Time User
Posted: Mon Feb 04, 2013 5:33 pm Post subject: Re: Bench grinder questions |
You can probably get the same grinder at Harbor Freight for around a hundred and fifty. I bought one three years ago but haven't taken it out of the box yet. My machinist has one and says it is a good grinder. |
| Back to top |
Bradracer18 Regular
Posted: Mon Feb 04, 2013 5:43 pm Post subject: Re: Bench grinder questions |
I've got the bigger craftsman one and like it! Its got a speed adjustment knob and works well! |
| Back to top |
IrvIA Regular
Posted: Mon Feb 04, 2013 5:48 pm Post subject: Re: Bench grinder questions |
If you got the bucks to spend, you can't go wrong with a Baldor unit. You'll have it a lifetime. Just my opinion. |
| Back to top |
David G Tractor Guru
Posted: Mon Feb 04, 2013 6:37 pm Post subject: Re: Bench grinder questions |
I have my dads baldor that he bought used in 1962, nice grinder. |
| Back to top |
Dalex Long Time User
Posted: Mon Feb 04, 2013 8:20 pm Post subject: Re: Bench grinder questions |
I do average shop work , and I wouldn't recomment those spec's. Baldor is a top brand , but get the 1/2 hp , 3600 rpm for grinding steel . The slow speed low hp sounds like its for sharpening knives or small drill bits |
| Back to top |
Jim in MN Regular
Posted: Mon Feb 04, 2013 8:44 pm Post subject: Re: Bench grinder questions |
I have a Jet 1hp 8" bench grinder. I have a grinding wheel on one side and a wire wheel on the other. Been very happy with it...works just as well as the Baldor I had at work. New they run around $250. Mine was $45 at an estae sale. |
| Back to top |
Stick welding Guest
Posted: Mon Feb 04, 2013 10:17 pm Post subject: Re: Bench grinder questions |
Not even close! Comparing a Baldor to a Jet, HF, Craftsman and any other consumer grinder is like comparing apples and peanuts. |
| Back to top |
JimDRIl Regular
Posted: Tue Feb 05, 2013 5:16 am Post subject: Re: Bench grinder questions |
I've got a Baldor I got used when the old P&H diesel plant closed, back in the 60s. Been performing well ever since. |
| Back to top |
Cliff(VA) Regular
Joined: 19 Aug 2008 Posts: 259 Location: White Post, VA
Posted: Tue Feb 05, 2013 6:05 am Post subject: Re: Bench grinder questions |
I have a Baldor 7" 1800rpm commercial grinder that I bought at auction for $60. Wonderful machine. It is my most treasured power tool, even in front of my Delta Unisaw.
I find the MOST important thing in a grinder, is cast iron tool rests. If it has sheet metal tool rests they get bent and are impossible to keep square to the stone. Look for a model that has good tool rests.
Cliff (VA)
I had a 6" Baldor hobby grinder. I burned it out. Baldor makes junk too. |
| Back to top |
Posted: Tue Feb 05, 2013 6:15 am Post subject: Re: Bench grinder questions |
You might want to check their web site and see where they are made now days. Our good buddy china. |
| Back to top |
George Marsh Tractor Expert
Joined: 05 Aug 2009 Posts: 2997 Location: terre haute
Posted: Tue Feb 05, 2013 7:56 am Post subject: Re: Bench grinder questions |
A 1/4 hp 1800 motor is good for a wire brush. To sharpen mower blades you want a minimum of 3/4 hp 8 inch, 3600, and a 36 grit wheel. |
| Back to top |
Awlknottedup Regular
Posted: Tue Feb 05, 2013 10:23 am Post subject: Re: Bench grinder questions |
I have a Baldor on a metal stand that I picked up off Craig's list for $50. It is 1/3 HP 3600 RPM and does a good job for what I need.
| Back to top |
Ellis Kinney Long Time User
Posted: Tue Feb 05, 2013 2:32 pm Post subject: Re: Bench grinder questions |
The 1750 rpm grinders are generally used for sharpening tools because they don't heat the metal as quickly. Ellis |
| Back to top |
oliver power Regular
Posted: Tue Feb 05, 2013 5:37 pm Post subject: Re: Bench grinder questions |
I too have the same grinder, only it says "Delta" on it. It is an 8" model, with variable speed dial. I like it a lot. Highly recommend it to anyone wanting a good all around bench grinder. The wheels are not the best quality. After dressing them, they turned out to be ok. You can always buy higher quality wheels when the time comes. I"m still on my originals after about 10 years now. |
| Back to top |
