| Author |
Message |
TJF Regular
Posted: Mon Feb 04, 2013 4:43 pm Post subject: 706 head gasket question |
Ok i have a 706 diesel that was blowing water out the radiator. So i figured busted head well i was correct bust all over. So i had one that was good no cracks after magnaflux. I installed it and now i think im blowing water worse than before. The head was resurfaced and valves redone. I used a felpro gasket set and torqued it 15 lb incraments after the first 50 lbs. Any ideas i was told to use coppercoat on the gasket? thanks |
| Back to top |
donwillis1949 Guest
Posted: Mon Feb 04, 2013 4:51 pm Post subject: Re: 706 head gasket question |
i did the same on a hough 50 loader with the 282 diesel blow water out and over heat so i changed the water pump boiled out the radiator and a new thermostat still does it so i just took the thermostat out as a quick fix and im not geting water in the oil so im thinking a sleave? possibly |
| Back to top |
TWL Regular
Posted: Mon Feb 04, 2013 5:15 pm Post subject: Re: 706 head gasket question |
There are several that say the felpro gaskets are no good and have had this same issue. Get one from caseih copper coat both sides. This is suppose to be the answer. Not going from experience, only from what I"ve read. |
| Back to top |
mkirsch Tractor Guru
Posted: Tue Feb 05, 2013 6:03 am Post subject: Re: 706 head gasket question |
Is the mating surface on top of the block true? |
| Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6532 Location: Delta,colorado
Posted: Tue Feb 05, 2013 8:15 am Post subject: Re: 706 head gasket question |
Ckeck deck for warpage with a sraightedge and feeler gauge.Check sleeve protrusion.Do you have a cavatated sleeve? |
| Back to top |
656 runner Guest
Posted: Sat Feb 09, 2013 11:35 am Post subject: Re: 706 head gasket question |
I resently bought a caseih gasket set and the head gasket was made by felpro. I then bought a felpro set and put gaskets side by side, same gaskets. Felpro set is better deal due to price and included injector seals. |
| Back to top |
D. Schwantes New User
Posted: Sat Feb 09, 2013 9:54 pm Post subject: Re: 706 head gasket question |
Use new head bolts and make sure they do not bottom out in their holes. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
