| Author |
Message |
2x4 Tractor Expert
Posted: Mon Feb 04, 2013 5:41 pm Post subject: OT:2001 Chevy 2500 fuel pump? |
2001 Chevy 2500 6.0 l. engine. Went 4 miles from the house to help cut up trees from the tornado. Parked outside HQ to ask where they needed help. P-up running great, shut down normally. Tried to start it, run but die, run, die few seconds later. Ran rough what few seconds it ran, then died, numerous times. Check fuses, OK; new fuel filter (Prolly first ever) at 120,000. Well used when I got it. No difference. Pull my 2000 up beside the "01. Can't hear fuel pump in tank of "01, can hear it on '00. Mileage is about right for fuel pump to go. Owners Manual doesn't even mention having a fuel filter, much less how to change in-tank fuel pump. Have put a new fuel pump in my '89 Nissan. Question is how do I do it with this beast? Of course, I just put 30 gal. in the tank. |
| Back to top |
WV2CYL Regular
Posted: Mon Feb 04, 2013 6:35 pm Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
My experience with chevy fuel pumps is that we crawl under the truck, loosen the bed bolts slide the bed back and then you are on top of the tank, Some of them, particulary S 10 have all the connections there, all covered with dirt, but a lot easier to cleanup and take the unit out, Some units have O rings and twist tops. Generally use a punch to get them to twist. |
| Back to top |
J bliler Guest
Posted: Mon Feb 04, 2013 6:45 pm Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
Just lift the bed with an engine lift. Remove the bed bolts and the two wiring plugs that are just in front of bumper Filler neck must be taken loose at side of bed. I cut a piece of 2by 6 that fit under the bed rails to lift the bed. Easy to get the balance. Roll the bed back the three feet you need to work. I bought my pump on Amazon for under $100. Great deal and work fine No need to remove fuel in tank or deal with working under truck too much |
| Back to top |
Bob Tractor Guru
Posted: Mon Feb 04, 2013 7:22 pm Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
Have a 2001 Yukon. Have done the fuel pump TWICE in 120,000 miles. Used a genuine GM/Delphi replacement the first time. BTW, NO box you can left up or slide back on THAT beast! |
| Back to top |
2x4 Tractor Expert
Posted: Mon Feb 04, 2013 7:45 pm Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
didn't think to mention it has a Knapheide tool body bed on it. |
| Back to top |
Kyle in KY Regular
Posted: Mon Feb 04, 2013 8:20 pm Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
Sometimes if you give the bottom of the fuel tank below the fuel pump a good wack with a hammer, it will start the fuel pump working to allow you to move the vehicle or pull it into a garage. If it does start, don"t turn it off until you have it moved to where you want. The trick has worked several times allowing us to get the vehicles inside to shop. Just my 2cents. |
| Back to top |
ericy Regular
Posted: Mon Feb 04, 2013 9:21 pm Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
Once you do get the bed off or drop the tank you might want to check the power wires going to the pump--- I have a 92 3500 and my truck acted the same way towed it home dropped the tank and was told to check the wires before putting the tank back in---YEP A GREY WIRE HAD ROTTED_BROKEN. That of course after $240 pump that the ends of the old one broke off . Just my 2 cents |
| Back to top |
WGM Regular
Posted: Tue Feb 05, 2013 2:15 am Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
Change fuel filters every 30k and you will never change the pump. |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12409 Location: Twin Cities
Posted: Tue Feb 05, 2013 2:52 am Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
If you take it in to the dealer it will cost you $1200 and change to have it done.
Don't ask me how I know this. |
| Back to top |
John B. Tractor Expert
Posted: Tue Feb 05, 2013 5:16 am Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
Take all four front bolts out that hold the bed to the frame. Loosen the rear two but do not remove. Then have 2-3 friends help you raise the front of the bed up and prop it up with 4 x 4's. This is the easiest way to access a fuel pump. I put two fuel pumps on my little chevy blazer and they went out a month apart just due to a clogged filter. |
| Back to top |
OliverGuy Long Time User
Posted: Tue Feb 05, 2013 6:51 am Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
We've done a lot them around here. That's one of the few downfalls I've found on Chevy/Gmc's. On our service truck we dropped the tank to get to it. Is it possible to cut you a hole right above in your bed to get to the pump? Then just put a patch over it. Heard of it being done that way, but never did it. |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23610 Location: in front of computer
Posted: Tue Feb 05, 2013 7:28 am Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
Been there with mine. The replacement Delco whined almost as bad as the factor pump that failed.
Truck was loosing power on hills due to low fuel pressure . 2nd replacement was a Carter E85 compatable pump purchased through Summit Racing.
Truck has never ran so quiet or so well since. |
| Back to top |
2x4 Tractor Expert
Posted: Tue Feb 05, 2013 9:48 am Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
yes it would be possible with the tool body bed. just a sheet of plate metal, one layer, as far as know. |
| Back to top |
2x4 Tractor Expert
Posted: Tue Feb 05, 2013 11:19 am Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
local guy told me that trick also. Didn't work. Thanks anyway. |
| Back to top |
karl f Tractor Expert
Posted: Tue Feb 05, 2013 6:05 pm Post subject: Re: OT:2001 Chevy 2500 fuel pump? |
Ultradog,
come up to Foley MN, the dealer there has a shop rate of only 75 an hour and the newest partsman is a tractor lover...
karl f |
| Back to top |
