| Author |
Message |
awchevy Regular
Posted: Tue Feb 05, 2013 3:52 pm Post subject: factory turbo kit |
What moline tractors had a factory turbo kit that you could
have a dealer install back in the day? Thanks for the info. |
| Back to top |
Alan K Tractor Expert
Posted: Tue Feb 05, 2013 4:32 pm Post subject: Re: factory turbo kit |
From what I have heard, the factory turbos were mostly for higher altitudes for the LP models....Not 100% positive but that is what Ive heard..unless there were add ons later. I think there might have been on the A4T's. Someone on here will know more about them. |
| Back to top |
schrocky Guest
Posted: Tue Feb 05, 2013 5:18 pm Post subject: Re: factory turbo kit |
I dont think you will find any real "factory" turbos as production models (maybe expirmentals). You could get M&W's and possibly others but the Hi cube low rpm hi torque engines MM designed were not real turbo friendly and not designed to be.We ran one on a M602 but not for long. It seriously did nothing for that tractor. Oh I know they are out there just not factory that I ever heard of...Im sure somebody will argue |
| Back to top |
G1355 Long Time User
Posted: Tue Feb 05, 2013 5:26 pm Post subject: Re: factory turbo kit |
Weren't they called altitude compensators, think they were dealer installed on the g1355, and the a4ts, might be more those are the two I know of. |
| Back to top |
Posted: Tue Feb 05, 2013 5:45 pm Post subject: Re: factory turbo kit |
I think you are right. When I was in Vo-Tech I rememeber seeing an MM service manual that listed turbos, but only for use to restore horsepower to original specification not to increase horsepower. I think at that time, mainly on the G1000s. |
| Back to top |
awchevy Regular
Posted: Tue Feb 05, 2013 7:12 pm Post subject: Re: factory turbo kit |
Thanks. Just wondering what moline i can run a turbo on for pulling. |
| Back to top |
Posted: Tue Feb 05, 2013 7:15 pm Post subject: Re: factory turbo kit |
Yeah, I think your right, they weren't using them for power, know out in Colorado and out that ways there pretty common. |
| Back to top |
Posted: Tue Feb 05, 2013 7:16 pm Post subject: Re: factory turbo kit |
I've seen turbos put on the 504 and 585 for pulling, there's a bunch of them on youtube |
| Back to top |
Dieselbear Long Time User
Posted: Tue Feb 05, 2013 7:21 pm Post subject: Re: factory turbo kit |
I have what is left of a vista that had an "X" in the serial # that had one on it, I have also seen them on 1050's and A4t's |
| Back to top |
awchevy Regular
Posted: Tue Feb 05, 2013 7:29 pm Post subject: Re: factory turbo kit |
Do you have a picture of that turbo one with the x in serial? And im trying to find one that i can run in a farm stock class type. Its either gotta be factory or add on. Like m&w |
| Back to top |
JK2 Regular
Posted: Tue Feb 05, 2013 7:36 pm Post subject: Re: factory turbo kit |
The only ones I know of that show a turbo in the parts catalogs are in the A4T repair parts and supplement. The 504 diesel used in the A4T-1400 used a turbo on all of them. The 585 in the A4T-1600 had an "Altitude Compensator" that could be added & was listed in a supplement. The MM Engine Company that built 800 pwer units in Russelville, Arkansas offered a turboed THD 800 LP or NG engine.
M&W offered turbo kits for M5 thru M670 diesels as well as for G1000 thru G1050's. I never saw or heard of one for the 900 thru 950's |
| Back to top |
maj-mm Regular
Posted: Tue Feb 05, 2013 7:54 pm Post subject: Re: factory turbo kit |
A4T-1400 with D504 engine had "factory Turbo" aka "Altitude Compensator" availble. also some G1000's and other "late" tractors got them added by dealers, as well as some LP-Gas models. the "factory" MM Turbo, was a M&W unit. |
| Back to top |
Jeff Gravert Regular
Posted: Tue Feb 05, 2013 8:32 pm Post subject: Re: factory turbo kit |
I have a M&W set up on a Vista that I would sell. Going to put tractor back original once restored. 308-940-0255 Jeff |
| Back to top |
Posted: Wed Feb 06, 2013 5:02 am Post subject: Re: factory turbo kit |
Here's one on a g1355, 585 diesel someone made found this picture awhile back, the guy said he made it himself and the turbo was from a 1086 ih.
| Back to top |
mmdiesel Regular
Posted: Wed Feb 06, 2013 9:55 am Post subject: Re: factory turbo kit |
I will give my opinion. I think the turbo or altitude compensator was designed for the 504 diesel engine of the A4T-1400. I read somewhere a few years back that the A4T had a stronger (maybe thicker) crank than the G1000, 1050 etc. and only the A4T crank could take a turbo for prolonged periods such as farming. There are lots of pulling tractors out there with the 504 or 585 engine and a turbo. My cousin has a G1000 that he has lots of fun with.
| Back to top |
