| Author |
Message |
Jack Mayers Regular
Posted: Tue Feb 05, 2013 4:36 pm Post subject: 1968 Simplicity 717 Broadmoor Wiring Diagram? |
I usually come to this forum for information about my Fordson tractors but hopefully someone out there can help with my 1968 Simplicity 717 Broadmoor.
My father purchased the tractor new when I was in Vietnam. I have kept it until this day. The battery does not charge. I bought a new voltage regulator for it but still no luck. It has a starter/generator. If I charge the battery with a plug in charger it starts fine which leads me to believe that the starter/generator is good. I think it might be the wiring. Does anyone have a wiring diagram?
Thank you,
Jack Mayers
1957 Fordson Major Diesel
1957 Fordson Dexta Diesel
1961 Fordson Super Major Diesel Loader/Backhoe
19-- Ingersol 1600
| Back to top |
El Toro Tractor Guru
Posted: Tue Feb 05, 2013 5:31 pm Post subject: Re: 1968 Simplicity 717 Broadmoor Wiring Diagram? |
With the engine at 1/2 throttle use a volt meter to see if there's voltage on the A terminal on the S/G. Your S/G may need rebuilding. Hal |
| Back to top |
Posted: Tue Feb 05, 2013 5:41 pm Post subject: Re: 1968 Simplicity 717 Broadmoor Wiring Diagram? |
Your S/G is getting is battery voltage once the battery is charged using your battery charger. Use a volt meter set on dc volts measuring across the battery terminals when the engine is at 1/2 throttle or better. Should see around 14 volts or better. If you only see 12 volts your S/G isn't charging. Is that a Delco S/G? I have the same setup on my Wards tractor made by Gilson. Hal |
| Back to top |
Jack Mayers Regular
Posted: Tue Feb 05, 2013 5:45 pm Post subject: Re: 1968 Simplicity 717 Broadmoor Wiring Diagram? |
I will check first thing tomorrow. Do you know if there is a rebuild kit available for the S/G? |
| Back to top |
Jack Mayers Regular
Posted: Tue Feb 05, 2013 5:47 pm Post subject: Re: 1968 Simplicity 717 Broadmoor Wiring Diagram? |
I'm at work tonight but I think it's a Delco also. |
| Back to top |
SuperABen Regular
I have an IPL that has the wiring diagram.
Go here:
http://www.simplicitymfg.com/us/en/support/manuals
Use #990425 as your model number for the 717.
Ben W. in VA
OldPathsEquipment.com |
| Back to top |
Jack Mayers Regular
Posted: Tue Feb 05, 2013 5:55 pm Post subject: Re: 1968 Simplicity 717 Broadmoor Wiring Diagram? |
THANK YOU!!!!!! |
| Back to top |
Posted: Wed Feb 06, 2013 3:59 am Post subject: Re: 1968 Simplicity 717 Broadmoor Wiring Diagram? |
Remove the S/G and take it to a shop that repairs
alternators, starters and generators. They will disassemble the generator after installing it on a test machine. They will machine the surface where brushes ride and install new bearings & brushes. I had mine rebuilt several years ago after almost 40 years of use. Check terminal A for voltage as I described earlier. If you have voltage there your wire may be broken. I paid $53.00 for the rebuild on the S/G. Hal |
| Back to top |
Posted: Wed Feb 06, 2013 4:07 am Post subject: Re: 1968 Simplicity 717 Broadmoor Wiring Diagram? |
I have a spare Delco S/G that rotates CW. Here's a pic of my tractor and you can see the S/G in the photo. Hal
| Back to top |
Jack Mayers Regular
Posted: Wed Feb 06, 2013 7:28 pm Post subject: Re: 1968 Simplicity 717 Broadmoor Wiring Diagram? |
Nice tractor. I didn't get a chance to check it today. Hopefully over the weekend. I'll let you know how I make out. Thanks for the information. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
