Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Freeing stuck tierods??
Post new topic    Yesterday's Tractors Forum Index -> Allis Chalmers
Hossman
PostPosted: Tue Feb 05, 2013 5:31 pm    Post subject: Freeing stuck tierods?? Reply to specific post Reply with quote
Guys, I have a set of used tierods I recently purchased and need to adjust them back in a bit. Does anyone got any ideas on how to free them up? The ones im replacing have been pretty buggered up by past owner. They took a torch and blew a kerf down the better part of the sleeve to "loosen" them up,complete with the nice slag drip all down the tierods. I have drilled a small hole on the bottom of the "new" tierods to get some penatrant into them and have been fillin with PB blaster.My next trick would be heat. I really dont want to mangle up this good set and wondered if yall had some tips for breaking these loose. As always thanks for any help, Hoss
Bob Bancroft
PostPosted: Tue Feb 05, 2013 5:40 pm    Post subject: Re: Freeing stuck tierods?? Reply to specific post Reply with quote
Soaking them is good. Heat is good. Working them over with a hammer is good. I don't mean such that you disfigure them, just hammering all over them with a good back up behind the rods.
At the shop where I used to work, we separated stuck PTO shafts by chaining one end to the bottom of the mast assy. of the forklift, and the other to the forks, and lifted!
Mike Neia
PostPosted: Tue Feb 05, 2013 6:08 pm    Post subject: Re: Freeing stuck tierods?? Reply to specific post Reply with quote
If you can hold the tube end try twisting the solid end with a pipe wrench.
Leon RCMo
PostPosted: Tue Feb 05, 2013 7:14 pm    Post subject: Re: Freeing stuck tierods?? Reply to specific post Reply with quote
Get after them with a air hammer. Will not beat them up badly.Used to do it all the time when I alighned big trucks.
Hendrik
PostPosted: Wed Feb 06, 2013 3:00 am    Post subject: Re: Freeing stuck tierods?? Reply to specific post Reply with quote
Using a forklift is a neat idea. Instead of a (shop)press you a have a "puller", for lack of a better word.
Mark-Ia
PostPosted: Wed Feb 06, 2013 7:04 am    Post subject: Re: Freeing stuck tierods?? Reply to specific post Reply with quote
Heat them up and quick cool them with water. They should almost fall apart.
Hossman
PostPosted: Wed Feb 06, 2013 4:42 pm    Post subject: Re: Freeing stuck tierods?? Reply to specific post Reply with quote
Hey Guys, Thanks so much for the ideas,there still soaking and tommorow gona try the heat and cool trick.If that dont get em gona put the ol air hammer to em. Thanks again, Hoss
S.C.
PostPosted: Sun Feb 10, 2013 6:31 am    Post subject: Re: Freeing stuck tierods?? Reply to specific post Reply with quote
I tried everything on my wd-45 but decided to just buy new ones. The only thing I didn't try was to use an air die grinder with a thin cut off wheel and split the tube to get it free. Make the split on the bottom so if any water gets in it can drain out. You can weld the split back up but it probably wouldn't hurt to leave it, then later if you want to change widths it should be easy.
dej(Jed)
PostPosted: Mon Feb 11, 2013 4:48 am    Post subject: Re: Freeing stuck tierods?? Reply to specific post Reply with quote
Just buy new ones..........
Bill Rowles
PostPosted: Mon Feb 11, 2013 11:31 pm    Post subject: Re: Freeing stuck tierods?? Reply to specific post Reply with quote
After soaking with PB Blaster, lay the end with the stuck threads on an anvil (or equivalent) and give it a good massage with a heavy hammer while rolling the threaded area around on the anvil with your free hand. That should breakup the rust in the threads without damage.
