Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
power adjust rims
Post new topic    Yesterday's Tractors Forum Index -> Massey Harris & Massey Ferguson
jedagi
PostPosted: Tue Feb 05, 2013 6:20 pm    Post subject: power adjust rims Reply to specific post Reply with quote
I set in to taking the rims off the center dish today. The square drive locks would not budge. I heated the outside of one and soaked it with power lube and heated some more. Then tried a 1/2 inch drive impact wrench that runs over 600 ft. lbs of torque. It didn't move a bit.
Anyone know any tricks foe getting them loose?
Tom from Buckeye Lake
PostPosted: Tue Feb 05, 2013 7:23 pm    Post subject: Re: power adjust rims Reply to specific post Reply with quote
I had to use. Oxy/acy torch on mine, then had to work them in and out, reheat, in and out, repeat, repeat. Did I say repeat? Smile
maxwell99
PostPosted: Tue Feb 05, 2013 7:26 pm    Post subject: Re: power adjust rims Reply to specific post Reply with quote
I have a to 35
I had one of the wheel to rim locks: lockup, I took the adj wheel lock off by loosing the two nuts. The lock came off, I guess you could take all four of them off.
Then put each of the locks in a vise, heat them with torch and they will break loose.
lee231
PostPosted: Tue Feb 05, 2013 7:32 pm    Post subject: Re: power adjust rims Reply to specific post Reply with quote
On the real stubborn ones, I"ve had to unbolt them from the rims and work on them in a vise. You can get the lube in them better too. I started on the bottom ones first. HTH"s lee
miner09
PostPosted: Wed Feb 06, 2013 5:22 am    Post subject: Re: power adjust rims Reply to specific post Reply with quote
The best way is to take the 2 bolts off like maxwell99 said. Thats what I did.
DiyDave
PostPosted: Wed Feb 06, 2013 5:56 am    Post subject: Re: power adjust rims Reply to specific post Reply with quote
If they are like the AC wheel locks ( the patent holder), take the bolts off, and drop them complete, as others have said. Heat and Beat in a vise, get 'em turning, a little, then take the snap ring off the back, and drive the cam pin out the front. Remember that the cam "bolt" is just a pin, with no threads. Run the pin against a wire wheel, till clean, and it fits the hole loose enough to turn. Re assemble all the parts, and Lube with Neversieze. Be sure not to lose the rail rider, that goes between the cam, and rail, when you dis-assemble.
jedagi
PostPosted: Wed Feb 06, 2013 4:35 pm    Post subject: Re: power adjust rims Reply to specific post Reply with quote
Thanks for the advice. I spent today removing dacals and sanding side panels. Ill get back the the wheels later. I was worried about breaking one of the locks.
Aaron For
PostPosted: Sun Feb 10, 2013 7:56 pm    Post subject: Re: power adjust rims Reply to specific post Reply with quote
I put them in a vise and heated with a torch until they were smokin hot. I then used Loctite Penetrating Oil and let it cool. I then torqued on em a little, then reheated/oiled. They eventually came loose. Lighter oils just flashed off but the heavier Loctite Penetrating Oil hung in there.
Aaron
willowbk
PostPosted: Mon Feb 11, 2013 7:19 pm    Post subject: Re: power adjust rims Reply to specific post Reply with quote
had same issues as everyone else,mine had been thru a complete fire of tractor. onbolted from center dish,remove snap ring from back side of cam and had to put them in a press and press out.30 ton press and a couple took all of it to pop. nice to use some never seize when reassemble. good luck.
