| Author |
Message |
nondem Long Time User
Joined: 17 Mar 2008 Posts: 511 Location: Tallahassee, Florida
Posted: Wed Feb 06, 2013 7:06 am Post subject: 8n Engine Specs |
Does anyone know if the specifications changed at all between the frontmount and sidemount blocks? I'm speaking about performance and capacity specs. I've read several different HP ratings that may or may not be describing the engine or drawbar rating. If someone knows more details(torque etc) besides what I've listed below or can correct this info - please do.
I'll dig out my manuals tonight and see what I find there....
30 H.P., "Flat-Head" 4 cylinder engine
4-speed transmission
2400 lbs Dry
540 RPM PTO System
Ferguson System 3 Point Hitch
Position Control and Automatic draft control
Produced from 1947-1952 at Dearborn, Michigan |
| Back to top |
souNdguy Tractor Guru
Posted: Wed Feb 06, 2013 7:17 am Post subject: Re: 8n Engine Specs |
6 vs 6.5 : 1 comp ratio.
head |
| Back to top |
kylemorley Regular
Posted: Wed Feb 06, 2013 10:54 am Post subject: Re: 8n Engine Specs |
Which is why the sidemounts require premium gas. |
| Back to top |
Posted: Wed Feb 06, 2013 11:13 am Post subject: Re: 8n Engine Specs |
not really.. it's still dismally low comp ratio..
gas back then wasn't hardly to the 70's |
| Back to top |
Posted: Wed Feb 06, 2013 5:42 pm Post subject: Re: 8n Engine Specs |
| soundguy wrote: | (quoted from post at 11:17:22 02/06/13) 6 vs 6.5 : 1 comp ratio.
head |
Wouldn't the higher compression raise the HP/Torque some? |
| Back to top |
Royse Tractor Expert
Posted: Wed Feb 06, 2013 6:14 pm Post subject: Re: 8n Engine Specs |
| nondem wrote: | (quoted from post at 21:42:19 02/06/13) | soundguy wrote: | (quoted from post at 11:17:22 02/06/13) 6 vs 6.5 : 1 comp ratio.
head |
Yes, and from memory I think those HP ratings were 23hp early and 26hp late.
Someone will correct me if that's not right. My memory is far from perfect.  |
| Back to top |
Ken(Ark) Long Time User
Posted: Wed Feb 06, 2013 6:29 pm Post subject: Re: 8n Engine Specs |
| nondem wrote: |
Raising the compression is probably the cheapest way to increase horsepower on any motor . Problem with the flatheads is the large combustion chamber , so getting 7.0:1 would be about the best you could get with a normal carb , then you would only get another pony or two .
Raising the rpm to 3k would get you about 10 more ponies .
Higher octane would not come into play until your compression ratio exceeded about 9 to 1 . |
| Back to top |
Posted: Fri Feb 08, 2013 12:28 pm Post subject: Re: 8n Engine Specs |
later engines are spec'd hgher hp. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
