| Author |
Message |
Bluegill Bill New User
Posted: Wed Feb 06, 2013 12:23 pm Post subject: Gas 2600 Ping/knock |
I have a 77 Ford 2600 that has a slight knock or ping when cold and first cranked. After warm it sounds smooth with no unusual noise and runs and operates great. The tractor only has 906 hours on it and I was wondering if my timing could be off a little or is this normal upon cold start up for an older gas motor? Thanks |
| Back to top |
Dean Tractor Guru
Posted: Wed Feb 06, 2013 12:34 pm Post subject: Re: Gas 2600 Ping/knock |
Spark knock upon cold start up is not normal. If spark knock, check the ignition timing.
Are you sure it is not piston slap?
Dean |
| Back to top |
Posted: Wed Feb 06, 2013 2:24 pm Post subject: Re: Gas 2600 Ping/knock |
If it were piston slap wouldn't it do it all the time and not just at start up? I'm not sure what the timing should be set on, but I do have a timing light and could check but need to find out the correct timing. |
| Back to top |
David G Tractor Guru
Posted: Wed Feb 06, 2013 2:51 pm Post subject: Re: Gas 2600 Ping/knock |
No, slap will diminish as the cylinders get splash oiling and the pistons warm and expand. I have never heard of a fast timing issue with a cold engine. |
| Back to top |
Posted: Thu Feb 07, 2013 2:20 pm Post subject: Re: Gas 2600 Ping/knock |
If it is piston slap maybe I should go to a multi-grade oil like a 10W30 or 15W40 so that the oil pump wouldn't have to work so hard at start up and would coat the cylinders quicker. I've been using a straight 30 weight, any suggestions would be great and thanks for the replies. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
