Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
BUST'N NUTS!
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Ford
Detmurds
PostPosted: Wed Feb 06, 2013 8:18 pm    Post subject: BUST'N NUTS! Reply to specific post Reply with quote
On my left rear wheel of my 1959 Workmaster,..I have only three lug nuts left of the six. The nuts are busted off from the outside of the wheel, and still in the inner part of it. How should I go about removing the bolts/threads/nuts? And who makes the replacement parts? Any help is appreciated!
shaun wallace
PostPosted: Wed Feb 06, 2013 8:46 pm    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
There is a plug in backplate that will let the new bolts be installed and I think they are avaible from this site
RodinNS
PostPosted: Thu Feb 07, 2013 6:59 am    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
AS stated... find the plug towards the bottom of the axle housing. You should be able to drive them out with a drift punch, then install new ones in the same manner with a heavy hammer and drift. Probably available here, CNH, NAPA, etc. Not hard to find.
Rod
Detmurds
PostPosted: Thu Feb 07, 2013 12:36 pm    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
Thanks for the reply,..but it is another lug nut, not a plug. I will go out there and see if punching it out will work or not.
Royse
PostPosted: Thu Feb 07, 2013 2:03 pm    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
3 of 6? Are you talking about the bolts that hold the outer rim to the center disk?
There should be eight holding the center disk to the axle/hub. No?
Detmurds
PostPosted: Thu Feb 07, 2013 2:48 pm    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
Royse wrote:
(quoted from post at 15:03:24 02/07/13) 3 of 6? Are you talking about the bolts that hold the outer rim to the center disk?
You are correct,..there are 8 of them.
Detmurds
PostPosted: Sun Feb 10, 2013 8:51 pm    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
So hey,..those lug nuts on the inside of the wheel are independent from those on the outside? Is that what I am being told here?
Sean in PA
PostPosted: Mon Feb 11, 2013 3:58 am    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
Detmurds wrote:
(quoted from post at 00:51:39 02/11/13) So hey,..those lug nuts on the inside of the wheel are independent from those on the outside? Is that what I am being told here?
That depends on what you're calling the "inside" and the "outside".
The nuts closer to the center of the wheel and axle hold the center of the wheel to the axle. The nuts out near the rim of the wheel, where the center of the wheel meets the rim of the wheel, hold the center to the rim, and yes, the 2 are independent of each other, but you need all of them to hold the tractor up.
If you're calling the "inside" where the studs come out through the hole on the inboard side of the brake backer plate, and the "outside" where the studs stick out where the lug nuts hold the center of the wheel to the studs, then the "inside" and the "outside" are just opposite ends of the same studs.
Detmurds
PostPosted: Mon Feb 11, 2013 8:45 am    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
Thanks Sean!
Detmurds
PostPosted: Mon Feb 11, 2013 7:45 pm    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
So,..to remove that inner ring bolt which has a nut on each end,..all I have to do is remove the nuts, and knock out the threaded bolt,..or is it threaded all the way through?
Detmurds
PostPosted: Wed Feb 13, 2013 6:39 pm    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
Must I turn this bolt, or knock it through?
Sean in PA
PostPosted: Wed Feb 13, 2013 6:56 pm    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
I'm not sure what you're referring to when you say " that inner ring bolt which has a nut on each end". Can you post a picture so we can understand what you're referring to?
Detmurds
PostPosted: Wed Feb 13, 2013 8:11 pm    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
They are the very only bolts going through the wheel that has a nut on both sides. This is not the bolts closest to the rubber of the tire. Just the bolts near the hub.
Royse
PostPosted: Wed Feb 13, 2013 8:29 pm    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
Detmurds wrote:
(quoted from post at 00:11:46 02/14/13)
Unless someone has done some modifications, there should not be bolts there
with nuts on both ends. That's probably what's confusing me.
They should either be pressed in studs or bolts.
As Sean said, a picture would really help. Below is the part diagram and I think
you are referring to part number 24 on the upper right?
Larry NCKS
PostPosted: Thu Feb 14, 2013 5:47 am    Post subject: Re: BUST'N NUTS! Reply to specific post Reply with quote
I think maybe I have the answer that's been missed here. Detmurds, there is a ring of bolts that secure the backing plate and outer axle bearing flange to the axle housing itself. These would have nuts on the inside. Do not remove these. This ring of bolts will have a smaller diameter than the lug bolts.
Find the access hole in the brake backing plate that everyone has been pointing you to. Remove the cover. Align the broken lug bolt with this hole and drive it out through the hole. This is a hammer and punch job. drive the replacement in the same way. (If you happen to have an air hammer this makes life so much easier) Rotate the axle until all broken lug bolts have been replaced. With only 3 of 8 left, I might be suspicious of the integrity of these 3 and replace all 8 while I was at it.
NOTE: It may be easier to do this with the brake drum removed.
NOTE: The final draw in of the new bolts may need to be preformed by drawing up the lug nuts.
View user's profile AIM Address
Goto page 1, 2  Next
Page 1 of 2
