Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
630 diesel thermostat bypass tube
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
cnh
PostPosted: Wed Feb 06, 2013 11:37 pm    Post subject: 630 diesel thermostat bypass tube Reply to specific post Reply with quote
I am working on an early 630 diesel, which has the thermostat in the upper rad hose and also has a thermostat by-pass tube. I cannot get the large square cut grommet seals for the by-pass tube from Case any longer, and am wondering if anyone has any ideas where to locate these other than Case. I believe the part number is/was 222-29. Thank you.
mEl
PostPosted: Thu Feb 07, 2013 4:42 am    Post subject: Re: 630 diesel thermostat bypass tube Reply to specific post Reply with quote
cnh wrote:
(quoted from post at 00:37:42 02/07/13) I am working on an early 630 diesel, which has the thermostat in the upper rad hose and also has a thermostat by-pass tube. I cannot get the large square cut grommet seals for the by-pass tube from Case any longer, and am wondering if anyone has any ideas where to locate these other than Case. I believe the part number is/was 222-29. Thank you.
If you are talking about the connection between the timing cover and the thermo housing, a short big pipe with an oring groove in the end I could be corrected but that is a much later engine or timing cover setup than the 630 came standard with. In any case, the part number that you give does not sound like a Case number as most start with a G or A. The Case parts site is down and advises you to see a dealer right now so I can't look it up.
Adirondack case guy
PostPosted: Thu Feb 07, 2013 6:08 am    Post subject: Re: 630 diesel thermostat bypass tube Reply to specific post Reply with quote
Mel,
I was thinking the same thing. The only bypass that I was aware of was the hollow 7/16 capscrew behind the water pump. What he was refering to sounded like the lifesaver sized rubber seal on a DB tractors. I am not familiar with what they did on the 207s.
PS I got a kick out of your E-mail about Obammy's big day.
Loren
JGarner
PostPosted: Thu Feb 07, 2013 1:43 pm    Post subject: Re: 630 diesel thermostat bypass tube Reply to specific post Reply with quote
Take a look at this site, it may help. I am betting the 222 is the manufacturer's size code and 29 is a material.
http://www.epm.com/square_cut.htm
Jim
cnh
PostPosted: Thu Feb 07, 2013 6:36 pm    Post subject: Re: 630 diesel thermostat bypass tube Reply to specific post Reply with quote
This tube can be viewed on the online parts lookup on page 34, in the sub-box on the top right of the picture. I believe the whole assembly (tube, seals, nuts, nipples) is part #A36018. This is a very similar tubing design as the fuel lines on this unit, just in a larger size. The nuts have "imperial flex" stamped on them. The tube size is 1/2" and the nipple the nut threads on is 13/16". Any help would be appreciated. I will attempt to download some photos as well. Thank you.
cnh
PostPosted: Thu Feb 07, 2013 6:54 pm    Post subject: Re: 630 diesel thermostat bypass tube Reply to specific post Reply with quote
pictures
cnh
PostPosted: Thu Feb 07, 2013 7:23 pm    Post subject: Re: 630 diesel thermostat bypass tube Reply to specific post Reply with quote
pictures
cnh
PostPosted: Thu Feb 07, 2013 7:28 pm    Post subject: Re: 630 diesel thermostat bypass tube Reply to specific post Reply with quote
Thanks for the web site link! lots of good info and helped alot!!
Adirondack case guy
PostPosted: Thu Feb 07, 2013 7:31 pm    Post subject: Re: 630 diesel thermostat bypass tube Reply to specific post Reply with quote
It looks like it may have been a field installed kit, as there are no bosses for the fittings to screw into, and the fittings don't look exactly straight in the castings. We had problems with the first 630s and got a service bulletin telling us to drill a hole length ways in the capscrew behind the water pump, that screws into the head. I have never seen a pipe like that on a 188.
Loren
cnh
PostPosted: Thu Feb 07, 2013 8:42 pm    Post subject: Re: 630 diesel thermostat bypass tube Reply to specific post Reply with quote
It is quite possible that it is an update. I do not think it was fabricated by the average farmer, it just looks too good for that. If anyone knows of a service bulletin or product update, I would sure like to know more. Thanks again. Also, not sure why pictures uploaded twice...lol.
