Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Countersink angle
Post new topic    Yesterday's Tractors Forum Index -> Tool Talk
fullmer
PostPosted: Thu Feb 07, 2013 9:56 am    Post subject: Countersink angle Reply to specific post Reply with quote
Looking to buy a 1 1/2 inch countersunk bit to enlarge a hole in 1/4 steel what angle is better 60 80 90 ??
Dalex
PostPosted: Thu Feb 07, 2013 10:21 am    Post subject: Re: Countersink angle Reply to specific post Reply with quote
can you measure the angle of the screw head ?
big fred
PostPosted: Thu Feb 07, 2013 11:12 am    Post subject: Re: Countersink angle Reply to specific post Reply with quote
Pretty much depends on the fastener you're using. I suspect you'll find it's either a 100 degree or 80 degree included angle on the fastener head.
fullmer
PostPosted: Thu Feb 07, 2013 2:09 pm    Post subject: Re: Countersink angle Reply to specific post Reply with quote
I will be using like a drill bit to go up to a larger pin size drilling all the way thru
Dalex
PostPosted: Thu Feb 07, 2013 2:19 pm    Post subject: Re: Countersink angle Reply to specific post Reply with quote
Ok , then you are looking for a reamer ...A Counter sink won't drill worth a hoot....
Don-Wi
PostPosted: Thu Feb 07, 2013 2:28 pm    Post subject: Re: Countersink angle Reply to specific post Reply with quote
How thick of material are you drilling through? A step drill comes to mind if it's sheet metal. A reamer isn't what I'd recommend.
Donovan from Wisconsin
fullmer
PostPosted: Thu Feb 07, 2013 3:26 pm    Post subject: Re: Countersink angle Reply to specific post Reply with quote
A bridge reamer would cost $200 in 1 1/2 the hole is egg shaped bad it is 1/4 plate looking for a cheaper bit
Dick L
PostPosted: Thu Feb 07, 2013 3:48 pm    Post subject: Re: Countersink angle Reply to specific post Reply with quote
Don't know what you have to work with but if I had it to do here I would grind the angle needed on an old 2 inch drill bit and clamp it down and keep taking a little out at a time until I had the desired OD of the taper. You can lay the bolt on the drill bit with the head down to get the angle you need by eye.
Russ from MN
PostPosted: Thu Feb 07, 2013 4:05 pm    Post subject: Re: Countersink angle Reply to specific post Reply with quote
Use a hole saw, lots of coolant, run it slow. Sometimes I drill some small holes around the circumference so there is somewhere for the chips to go. 1/4" should be easy. If you want a tight fit saw it a little under size and file it to fit. Clamp a piece of hardwood on top to keep the hole saw centered.
markiz41
PostPosted: Thu Feb 07, 2013 4:22 pm    Post subject: Re: Countersink angle Reply to specific post Reply with quote
How about 1-1/2 step drill?
http://www.amazon.com/MAGBIT-851-1500-MAG851-4-Inch-Diameter/sim/B005M27CGG/2
Not going to be cheap at $90.
Mike Kork
PostPosted: Thu Feb 07, 2013 4:55 pm    Post subject: Re: Countersink angle Reply to specific post Reply with quote
Just make a round hole and weld it over your egg shaped hole.
dhamps10
PostPosted: Thu Feb 07, 2013 5:16 pm    Post subject: Re: Countersink angle Reply to specific post Reply with quote
I have done that very thing, in close quarters, where a drill bit was too long. 60 will cut best.
Dennis
Bradracer18
PostPosted: Fri Feb 08, 2013 7:13 pm    Post subject: Re: Countersink angle Reply to specific post Reply with quote
what are you trying to do?
Typical countersinks are 82 and 90 degrees. Most machine screws are 82 degrees.
If you are trying to make a hole larger....a reamer is generally only if you are trying to make it say 0.030 larger or so. If its not extremely critical, I'd just throw it in the mill, center find the current hole and mill a hole the size you are looking for....easily be able to hit your desired dimension
ss55
PostPosted: Sun Feb 10, 2013 12:06 pm    Post subject: Re: Countersink angle Reply to specific post Reply with quote
Can you use an end mill bit, or an adjustable fly cutter?
