Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Oliver 77 clutch change ??????????
Post new topic    Yesterday's Tractors Forum Index -> Oliver, Cletrac, Coop and Cockshutt
showdown
PostPosted: Thu Feb 07, 2013 10:16 am    Post subject: Oliver 77 clutch change ?????????? Reply to specific post Reply with quote
Does anyone known if I can change the clutch without pulling the engine, if so how is it done? Thanks for any help.
J. schwiebert
PostPosted: Thu Feb 07, 2013 12:31 pm    Post subject: Re: Oliver 77 clutch change ?????????? Reply to specific post Reply with quote
Yes, we used to do them all the time. Kep point remove the long PTO shaft first. Does your tractor have the belt pulley drive housing?
Schim
PostPosted: Thu Feb 07, 2013 12:36 pm    Post subject: Re: Oliver 77 clutch change ?????????? Reply to specific post Reply with quote
Do you have a belt pulley on it? If so you more than likely will have to pull the motor.If you dont just take the pto clutch housing off, unbolt the pto clutches, and pull the long shaft out. Dont have to pull it out all the way unless you want to look at it. Then take the sheet metal off, unhook the coupler to the trans, and unbolt the bell housing and pull it out.
J. Schwiebert
PostPosted: Thu Feb 07, 2013 1:33 pm    Post subject: Re: Oliver 77 clutch change ?????????? Reply to specific post Reply with quote
You fold the panel over, take the pulley housing off and let the engine in. We used to change 2 a day out in the country if the farmer would agree to remove the sheet metal and the fuel tank
showdown
PostPosted: Thu Feb 07, 2013 2:22 pm    Post subject: Re: Oliver 77 clutch change ?????????? Reply to specific post Reply with quote
Mine doesn't have the belt pulley. Does the bell housing come right out off the tractor when unbolted, does this then let you remove press. plate and replace clutch if needed? Thanks.
showdown
PostPosted: Thu Feb 07, 2013 2:30 pm    Post subject: Re: Oliver 77 clutch change ?????????? Reply to specific post Reply with quote
What do I use, where do I get a new clutch disc if needed. I do tractor pull this 77. Thanks...
J.Wondergem
PostPosted: Thu Feb 07, 2013 4:14 pm    Post subject: Re: Oliver 77 clutch change ?????????? Reply to specific post Reply with quote
I'd go to a place that rebuild truck clutches and see about a ceramic clutch disk, and a new pressure plate.
K. Schwiebert
PostPosted: Thu Feb 07, 2013 6:44 pm    Post subject: Re: Oliver 77 clutch change ?????????? Reply to specific post Reply with quote
Yes. Since you pull it do you have a PTO or did you shed it remove the weight? Which clutch do you have? You can put a bigger clutch that standard in there.
showdown
PostPosted: Thu Feb 07, 2013 7:18 pm    Post subject: Re: Oliver 77 clutch change ?????????? Reply to specific post Reply with quote
I did remove the pto. The clutch and press. plate are stock. I'am trying to get and idea of what to replace it with if it does fail in the future. If I pull the bell housing off can I see the amount of wear left on it? Where do I get a replacement?
chucksoliver77
PostPosted: Thu Feb 07, 2013 8:06 pm    Post subject: Re: Oliver 77 clutch change ?????????? Reply to specific post Reply with quote
how big is your engine and how much power does it make? that will tell us what you need for a clutch. Chuck
