| Author |
Message |
Blackland Dan Regular
Posted: Thu Feb 07, 2013 1:19 pm Post subject: Bore Sleeve? |
Has anyone ever bored a G jug into the water jackets and then resleeve? If so, how far did you take it. How did it work? Thanks, Dan |
| Back to top |
mmdiesel Regular
Posted: Thu Feb 07, 2013 2:38 pm Post subject: Re: Bore Sleeve? |
I have some UB diesel jugs bored to 5.125" I never used them, because I could not find flat top diesel pistons. |
| Back to top |
Posted: Thu Feb 07, 2013 4:19 pm Post subject: Re: Bore Sleeve? |
Did you bore into the water jackets and re-sleeve? |
| Back to top |
mmmmmmmmmmmmmmmmm Guest
Posted: Thu Feb 07, 2013 4:40 pm Post subject: Re: Bore Sleeve? |
5.75 bore but you better know what your doing. |
| Back to top |
mightymolinekid Regular
Posted: Thu Feb 07, 2013 5:41 pm Post subject: Re: Bore Sleeve? |
What would you want for those jugs? I may be interested. Shoot me an E-mail if you could. |
| Back to top |
newby puller New User
Posted: Thu Feb 07, 2013 9:16 pm Post subject: Re: Bore Sleeve? |
Yes I had a set of 403 g jugs bored to 5.5 sleeved and hard blocked at cornets machine shop turned out nice never been installed. Wanted to stay away from 800 jugs some rules wont let u run 800 stuff so went a different way they are 4 sale |
| Back to top |
Dieselbear Long Time User
Posted: Fri Feb 08, 2013 3:56 am Post subject: Re: Bore Sleeve? |
You can take the recast solid blocks to 6 inches |
| Back to top |
Posted: Fri Feb 08, 2013 6:16 am Post subject: Re: Bore Sleeve? |
Yes went into water jackets resleeved filled with hardblock. Run water in the heads not the blocks. Its a little more expensive to do this way but but like I mention was staying away from 800 jugs weight of jugs. Keep it a short jug motor. Just my two cents |
| Back to top |
Posted: Fri Feb 08, 2013 8:10 am Post subject: Re: Bore Sleeve? |
Just what I wanted to hear guys. What is "Hardblocked"? Thanks to all. |
| Back to top |
mmdiesel Regular
Posted: Fri Feb 08, 2013 1:08 pm Post subject: Re: Bore Sleeve? |
I paid about $1000 for the jugs. I might use them sometime. I have lots of "projects" to build. It looked like I would need to grind the crankcase to make the jugs fit. Does that sound right? |
| Back to top |
brentp4455 Regular
Posted: Sat Feb 09, 2013 10:00 am Post subject: Re: Bore Sleeve? |
hardblock is a substance somewhat similar to cement but NOT the same. You pour it in the water jackets and it solidifies to strengthen the block. its a good idea because blocks can be weakened by large bores. |
| Back to top |
