660 combine motor
Goto page 1, 2  Next
outsidersag
PostPosted: Thu Feb 07, 2013 6:25 pm    Post subject: 660 combine motor Reply to specific post Reply with quote
Anyone have the specs for the 4cly motor on the 660 combine? Also will the internal parts fit in a VAC motor? thanks
Adirondack case guy
PostPosted: Thu Feb 07, 2013 6:31 pm    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
No, the 201 is a 5 main engine.
Loren
outsidersag
PostPosted: Thu Feb 07, 2013 6:37 pm    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
Will the 660 motor bolt to the bell housing on a VAC?
1370rod
PostPosted: Thu Feb 07, 2013 6:52 pm    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
No, I tried that years ago. Bolt pattern is spread out a bit and engine is longer. With some work you could make it fit.
TimBinWV
PostPosted: Thu Feb 07, 2013 6:58 pm    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
ACG, wasn"t the 188 gas used in the 660"s as well?
Adirondack case guy
PostPosted: Thu Feb 07, 2013 7:12 pm    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
Yes, I was thinking of my engone, but the 188 was also a 5 main brg. engine also
Loren
outsidersag
PostPosted: Thu Feb 07, 2013 7:14 pm    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
What HP is that motor? Are there any parts that will interchange to get more HP? Looking to build a 250-300hp VAC puller!
mattwillson
PostPosted: Thu Feb 07, 2013 7:18 pm    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
How much longer is it? I'm trimmin' up my dad's vac13 and although I have enough parts to do the motor, maybe this approach would give the little tractor a little more pep in her step when he wants to show off at the steam show on the dyno or pullin'.
1370rod
PostPosted: Thu Feb 07, 2013 7:20 pm    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
I don't know the answer to those questions, but I hope you can make it work, a 200 hp VAC would be sweet!
1370rod
PostPosted: Thu Feb 07, 2013 7:23 pm    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
Loren, do those 5 main gassers have the same bottom as the diesels?
Hoofer B
PostPosted: Thu Feb 07, 2013 7:27 pm    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
What would you do witha 200 hp VAC? Anything you wanted to!
outsidersag
PostPosted: Thu Feb 07, 2013 7:37 pm    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
That should have been 250-300 cubic inch. oops
Adirondack case guy
PostPosted: Fri Feb 08, 2013 5:30 am    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
Rod,
My guess would be they are the same, buy I don't have parts books to varify that. Mel would know more about that than me.
Loren
Case Nutty 1660
PostPosted: Fri Feb 08, 2013 6:16 am    Post subject: Re: 660 combine motor Reply to specific post Reply with quote
rod and main brgs are the same, cranks and rods are different
Goto page 1, 2  Next
Page 1 of 2
