| Author |
Message |
Bluegill Bill New User
Posted: Fri Feb 08, 2013 11:52 am Post subject: What Should I Use |
Should I use a straight weight or a multi-viscosity oil in a gas Ford tractor motor? I'm currently using a straight 30 weight but would like to know what others use. Seams I'm getting a little piston slap upon cold start up and wonder if the multi-viscosity might pump easier at start up, thanks. |
| Back to top |
David G Tractor Guru
Posted: Fri Feb 08, 2013 12:54 pm Post subject: Re: What Should I Use |
I would use 15W-40 or 10W-30 rotella or delvac. I run the 15W-40 but have everything heated inside in winter. |
| Back to top |
souNdguy Tractor Guru
Posted: Fri Feb 08, 2013 2:53 pm Post subject: Re: What Should I Use |
ant temp/region you can use a 30wstraight.. I'd opt for a 15w40.
better oil... |
| Back to top |
Hobo,NC Tractor Guru
Joined: 14 Jun 2007 Posts: 10611 Location: Sanford, NC
Posted: Fri Feb 08, 2013 4:43 pm Post subject: Re: What Should I Use |
I seriously doubt oil weight is going to cure your issue... |
| Back to top |
Posted: Fri Feb 08, 2013 5:53 pm Post subject: Re: What Should I Use |
yes a multi vis 10w30 or 15w40 will pump easier cold than 30w.. if you have piston slap.. that's a different issue.
I agree with hobo.. oil's not yer problem..
you are looking for a bandaid for a broke leg... |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
