Pics. of ferguson TO-30 crank pics
cole in OH
PostPosted: Fri Feb 08, 2013 1:13 pm    Post subject: Pics. of ferguson TO-30 crank pics Reply to specific post Reply with quote
Does any body have some close pics of a ferguson TO-30 crank all the way in? The middle journal is not lining up on my crank with the cap on unless I flip the cap around with the z120 facing up towards the camshaft side? Thanks
mattwillson
PostPosted: Fri Feb 08, 2013 5:52 pm    Post subject: Re: Pics. of ferguson TO-30 crank pics Reply to specific post Reply with quote
do the bearing tabs butt on the same side that way? If not, you have a problem. Maybe try it without the thrusters, they can be put in after
cole in OH
PostPosted: Fri Feb 08, 2013 6:26 pm    Post subject: Re: Pics. of ferguson TO-30 crank pics Reply to specific post Reply with quote
Yes that's with both tabs at the top and the crank is in there straight it has to do with the one cap if someone had some pics it would help! Thanks
cole in OH
PostPosted: Fri Feb 08, 2013 8:35 pm    Post subject: Re: Pics. of ferguson TO-30 crank pics Reply to specific post Reply with quote
Can the bearing cap get bent? the cap has a 2 or a 5 on one side of it and z120 on the other if it matters.
Jason S.
PostPosted: Sat Feb 09, 2013 5:52 am    Post subject: Re: Pics. of ferguson TO-30 crank pics Reply to specific post Reply with quote
I got a Z120 engine on an engine stand. I could take some pics of it if it would help you.
cole in OH
PostPosted: Sat Feb 09, 2013 6:31 am    Post subject: Re: Pics. of ferguson TO-30 crank pics Reply to specific post Reply with quote
Yea that would help thanks!
Jason S.
PostPosted: Sat Feb 09, 2013 8:21 am    Post subject: Re: Pics. of ferguson TO-30 crank pics Reply to specific post Reply with quote
Ok...it will be later tonight before I can take the pics. I am at work right now.
cole in OH
PostPosted: Sat Feb 09, 2013 3:54 pm    Post subject: Re: Pics. of ferguson TO-30 crank pics Reply to specific post Reply with quote
Ok thanks!
watco2
PostPosted: Sun Feb 10, 2013 7:03 am    Post subject: Re: Pics. of ferguson TO-30 crank pics Reply to specific post Reply with quote
The middle main bearing cap is a floating cap and must be installed in a perticular way. First, make sure there is plenty of lube, I use stp oil treatment so if the oil takes a little longer on the first startup it will stay on the bearings, the cleats on the bearing should be on opposet side from one another. Just finger tight the bolts after you install the two end caps and torque them. To tighten the middle cap you must do it with small increaments. As you tighten the bolts do so in 1/4 turns back in forth between the bolts. This allows the cap to seat itself with a floating action. If you tighten one side too much before the other the cap will not seat properly.
watco2
PostPosted: Sun Feb 10, 2013 7:11 am    Post subject: Re: Pics. of ferguson TO-30 crank pics Reply to specific post Reply with quote
Pics of TO-30 crank in block
Jason S.
PostPosted: Sun Feb 10, 2013 10:26 am    Post subject: Re: Pics. of ferguson TO-30 crank pics Reply to specific post Reply with quote
Cole in OH wrote:
(quoted from post at 00:54:49 02/10/13) Ok thanks!
The first pic is with the cap turned correctly where the bearing tabs are on opposite sides, the second pic is with the cap turned wrong and you can see it doesn't line up with the block and the bearing tabs are on the same side when it's turned wrong.
