| Author |
Message |
Laneman Regular
Posted: Fri Feb 08, 2013 1:30 pm Post subject: How do I remove hyd pump on 73 3000? |
IT manual says to remove hydraulic manifold. I don't see a hydraulic manifold unless it takes up half the pump. The lines go straight into the pump, there is a seam in the center of the pump. Do I split the pump in half and that is the manifold? Don't want to open the pump up and have its guts spill out. I don't see any other way to remove pump manifold. In the middle of a clutch job, really need a quick answer |
| Back to top |
Laneman Regular
Posted: Fri Feb 08, 2013 3:08 pm Post subject: Re: How do I remove hyd pump on 73 3000? |
From looking online it appears that the suction line just slips out of pump, pressure line is a flare fitting. |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12564 Location: Twin Cities
Posted: Fri Feb 08, 2013 3:14 pm Post subject: Re: How do I remove hyd pump on 73 3000? |
You will probably have to remove the clamp that holds the lines down by the the front of the right step plate. Then just give the suction line a jerk. It should come out. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
