Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Farmall engine C-263 distributor
Elder Al
PostPosted: Fri Feb 08, 2013 6:52 pm    Post subject: Farmall engine C-263 distributor Reply to specific post Reply with quote
I,m looking for a distributor rebuild kit,specifically the bushings,seal, and springs. Now that I"ve got it all torn apart, a good assembly diagram would also be very helpful.
Hugh McKinney
PostPosted: Fri Feb 08, 2013 8:33 pm    Post subject: Re: Farmall engine C-263 distributor Reply to specific post Reply with quote
Do you know who made the distributor? If it is a Delco I think that parts are fairly easy to find; any good old fashioned auto electric service could sell you the parts, again, if it is made by Delco--I have had Fletcher's Auto Electric in Shreveport, LA, do practically everything electrical in the C-281 in my 450.
the tractor vet
PostPosted: Fri Feb 08, 2013 8:40 pm    Post subject: Re: Farmall engine C-263 distributor Reply to specific post Reply with quote
You are SOL as at this moment i am in the same spot . And if you think i'll just go get a good used one now you need to do your home work as they might all LOOK the same and they will ALL fit BUT that is where it ends. They do NOT all have the same centrifugal advance cure . SO if it is out of say a 560 then you must get one FROM a 560 , if it is out of a 706 then you must get one from a 706 and so on.
Elder Al
PostPosted: Fri Feb 08, 2013 10:06 pm    Post subject: Re: Farmall engine C-263 distributor Reply to specific post Reply with quote
Ya, i do believe it's a delco. When pulling it apart i found two different size springs, making me think someone has cobbeled it. I have taken the dist. off a 656 that i am currently restoring bumper to bumper, droped it in the 560 and it runs better than ever before so i don't know what to think about the misfit idea... There are lots of 560's laying around this country so maybe that would be the best option. I would like to find a darn good manual that has more detail than most on the market.
pete 23
PostPosted: Sat Feb 09, 2013 12:02 pm    Post subject: Re: Farmall engine C-263 distributor Reply to specific post Reply with quote
The dist is not delco remy, IH had their own. Far as differet size springs that is very common to aquire a particuar advance curve. Like Vet says, good luck with bushing etc. IH does finally have a bushing available for the older four cyl IH distributor. Never did in the 40 years I worked at a dealer but do now. I put one in a couple years ago on a 400. You can always alter a distributor from a 706 if you have the moxy to do so. Increase the advance from 22 , or 25 , depending on age of 706 and make it into a 30 degree for a 560 if that is the model you have. Fortunatly, the busings , weights and pivot pins don't usually wear out as bad on those six bangers as they do on the four cyl engines.
Elder Al
PostPosted: Wed Feb 13, 2013 5:24 pm    Post subject: Re: Farmall engine C-263 distributor Reply to specific post Reply with quote
Thanks for the info. I"ll see what i can pick up salvage. u are rite, it is a 560. i pulled the dist out of my 656 and stuck in just to verify problem and it runs better than ever. I may try milling my own bushings---that should be a challenge.
