Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
ford 8000 help
Post new topic    Yesterday's Tractors Forum Index -> Ford
450dieselfan
PostPosted: Fri Feb 08, 2013 9:43 pm    Post subject: ford 8000 help Reply to specific post Reply with quote
just bought a 8000 its been sitting outside for 5+ years not stuck. i would like to start it and drive it home sould i be worred about if thier is water in the trans? also would else should i cheak? thanks
showcrop
PostPosted: Sat Feb 09, 2013 5:18 am    Post subject: Re: ford 8000 help Reply to specific post Reply with quote
[quote="450dieselfan"](reply to post at 22:43:53 02/08/13) [/quot
My 9000 had been in the weeds for seven years. We scrounged a wheel and tire, changed fuel filters and primed it up, put in a battery checked the oil and started it. We then drove it around to the shop, and did a full PM. There will be some water in all the housings. It gets there from condensation. I literally had gallons on my shop floor two weeks ago when the temp jumped twenty degrees in ten minutes. To remove the water, You don't say where you are, so I will assume it is water, not ice, just loosen the drains until water starts to dribble out, and when it changes to oil tighten it back up. You will need to slide the draw bar back to get to the back one. The fuel tank will contain all manner of contamination. There is a drain plug on the left bottom that you can remove to drain until it turns clear. The clear fuel will be good. Be sure as part of the PM to change the oil in the injection pump. Check the radiator for crud/mud. Due to the oil bearing tubes in the front they tend to get blocked. An hydraulic oil change will be advisable, but not until you can circulate the oil some to get it warmed up. A good way to do this is to operate an hydraulic implement for awhile. Moving and heating the oil will enable you to get some crud out with it. It probably has a half inch on the bottom. CHECK THE COOLANT SCAs !! Drain some off see how bad it looks. I strain and reuse half myself. When refilling include treatment.
RodinNS
PostPosted: Sat Feb 09, 2013 10:03 am    Post subject: Re: ford 8000 help Reply to specific post Reply with quote
Like showcrop said... I think I'd pull the drains on all of the sumps before starting it... just to drain off whatever water is there and make sure that there is some oil in it...
I'd not worry about it being up to spec for a short drive as long as it's safe.
Changing the fuel filters and making sure there's a good flow from the tank is also a very good idea so it doesn't quit on the side of the road...
Rod
