Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
ih td340 crawler with 166 diesel engine glow plug.problem
farmall help
PostPosted: Fri Feb 08, 2013 9:58 pm    Post subject: ih td340 crawler with 166 diesel engine glow plug.problem Reply to specific post Reply with quote
We have a Ih TD340 with a 166 diesel engine. We put new
glow.plugs in and only pushed switch for few.seconds and it
mushroomed the glow plug tips. Does this circuit need.a
resistor before the glow plugs? How are the glow plugs
supposed.to be wired.or.hooked up? Got as a project and
wont start without the glow plugs working properly. Any
ideas?
pete 23
PostPosted: Sat Feb 09, 2013 12:22 pm    Post subject: Re: ih td340 crawler with 166 diesel engine glow plug.proble Reply to specific post Reply with quote
No resistor on those engines and they are hooked in parallel. In other words, hooking one directly to a 12 volt battery would not hurt it. However, high voltage like having a booster charger on it will fry them in seconds. Never exceed normal regulated voltage which would be about 14.5 volts. Even that high is not good. What I do on all those style glow plug engines is keep them on while cranking and after starting but do not let go of them and then reapply. The original generators did not have enough output to raise voltage to regulated voltage while holding glow plugs but once you let go then the voltage will rise. With an alternator you could very well reach regulated voltage even with glow plugs on. So, if you have correct plugs, only high voltage would blow them.
farmall help
PostPosted: Sat Feb 09, 2013 3:46 pm    Post subject: Re: ih td340 crawler with 166 diesel engine glow plug.proble Reply to specific post Reply with quote
Thankyou pete. The booster may have done it.
farmall help
PostPosted: Thu Feb 14, 2013 1:45 pm    Post subject: Re: ih td340 crawler with 166 diesel engine glow plug.proble Reply to specific post Reply with quote
mkirsch
PostPosted: Thu Feb 14, 2013 1:49 pm    Post subject: Re: ih td340 crawler with 166 diesel engine glow plug.proble Reply to specific post Reply with quote
You sure you got the correct plugs?
AFAIK some are series, some are parallel.
If you got the series plugs, they'd go *PIFF* if you hooked them directly to 12V.
