hesston 1090
DJM75
PostPosted: Sat Feb 09, 2013 3:38 am    Post subject: hesston 1090 Reply to specific post Reply with quote
looking for opinions on a 1090 got one near me for $2000. thanks
Fordfarmer
PostPosted: Sat Feb 09, 2013 5:59 am    Post subject: Re: hesston 1090 Reply to specific post Reply with quote
We ran a 1091 for quite a few years. Same machine, but a little newer, maybe some updates. Decent machine, but ours developed cracks in the frame around the gearbox. Check that area out pretty close. We replaced it with a MacDon with meshing steel rolls - drys hay a lot faster than Hesston's non-meshing rolls. Remember that you're looking at a 30+/- year old machine...check parts availability.
Adirondack case guy
PostPosted: Sat Feb 09, 2013 9:18 am    Post subject: Re: hesston 1090 Reply to specific post Reply with quote
Intermeshing rolls are fine in salky hays, but will shread the leaves off of tender crops like Alfalfa.
Loren.
rrlund
PostPosted: Sat Feb 09, 2013 9:47 am    Post subject: Re: hesston 1090 Reply to specific post Reply with quote
I saw a 1091 sell on an auction two months ago for $700. Guess it would depend on the condition and how bad you want one. New stuff's expensive.
Larry NEIL
PostPosted: Sat Feb 09, 2013 10:13 am    Post subject: Re: hesston 1090 Reply to specific post Reply with quote
Been using my 1091 for about 7 years and no problems except the lift tube wore and wouldn't mesh, had to weld it up again. $2000.00 seems $800 to $1000.00 high to me unless it has barley been used with a new sickle. That is a 30+ yr old machine.
Fordfarmer
PostPosted: Sat Feb 09, 2013 12:36 pm    Post subject: Re: hesston 1090 Reply to specific post Reply with quote
Not when they're adjusted properly - some of my hay is alfalfa mix and some is trefoil... no problems with knocking leaves off either one.
Brendon-KS
PostPosted: Sat Feb 09, 2013 1:27 pm    Post subject: Re: hesston 1090 Reply to specific post Reply with quote
If you visit the major alfalfa growing areas in California, Idaho, Arizona, Colorado, or about anywhere else you will have a hard time finding anything BUT intermeshing rolls being used. It's a proven design that has become standard in the industry.
dmiller
PostPosted: Sat Feb 09, 2013 4:46 pm    Post subject: Re: hesston 1090 Reply to specific post Reply with quote
I have used one for the past three years (a 1091). I like it. I paid $2200 for mine from a local small time used equipment dealer. I felt it was a bit high but came from a trustworthy source that I know goes through them well. I've had very little problems and no complaints.
Parts availability seems ok from what I've found on normal wear parts. The area around my gear box has been welded indicating the type of wear mentioned in other posts here.
I think price is regional. Around here anything smaller than 14 feet and less than 15 years old is becoming rare and us smaller guys are paying more to compete with each other for desirable small equipment.
JD Seller
PostPosted: Sat Feb 09, 2013 6:32 pm    Post subject: Re: hesston 1090 Reply to specific post Reply with quote
The Hesston 1090 and 1091 where a fairly good machine. They did have trouble around the sickle gear case but that usually was from the owner running a dull sickle or a bad sickle head.
Five years ago I would have said that $2000 was way too high a price. Now that is about market for one if it is usable. The cost of new is sky high so usable older equipment is selling higher.
DJM75
PostPosted: Mon Feb 11, 2013 6:07 am    Post subject: Re: hesston 1090 Reply to specific post Reply with quote
Thanks for the help fellas.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
