| Author |
Message |
newfarmer9 Regular
Posted: Sat Feb 09, 2013 8:26 am Post subject: White 2-105 Implements |
Hey all,
Looking at buying a 2-105, and I was just wondering what size of implements it would be able to handle (disc, cultivator, moldboard plow). We are in heavy clay loam here so I think a 15 foot disc, 20 foot cultivator, and 4-16 plow would be more than enough for it to handle. Thoughts?
Thanks for any help! |
| Back to top |
WGWKy2 Guest
Posted: Sat Feb 09, 2013 9:25 am Post subject: Re: White 2-105 Implements |
That sounds about right, I have 5X16 on mine and wish for 4 in some sod fields. |
| Back to top |
rrlund Tractor Guru
Posted: Sat Feb 09, 2013 9:45 am Post subject: Re: White 2-105 Implements |
I'd say you're right about in the ballpark. It's not a new tractor anymore. |
| Back to top |
Larry NEIL Tractor Expert
Joined: 20 Aug 2011 Posts: 1727 Location: Schaumburg, Illinois
Posted: Sat Feb 09, 2013 10:28 am Post subject: Re: White 2-105 Implements |
I used to farm with an Oliver 1950T, about the same HP and it pulled a 7 shank Glencoe soil saver and a IH 690 18' disc with no problems.
Was told by an an old mechanic/farmer that the best way to tell if what yo're pulling is too much is to advance the throttle. If it just pours out more black smoke, but the rpm's and speed don't go up, you have too much behind you. |
| Back to top |
hoosierhog Regular
Posted: Mon Feb 11, 2013 11:10 am Post subject: Re: White 2-105 Implements |
Well In my soils I run those Implements on my 1850 Oliver but
the disc I use is a white 252 18ft with 7.5 inch spacing I think
you got the right size implements but I think you could handle
5-16plow or a disc 15-18ft depending on how heavy the disc
is. |
| Back to top |
newfarmer9 Regular
Posted: Mon Feb 11, 2013 4:47 pm Post subject: Re: White 2-105 Implements |
I find in our soils I generally need to take 1/3 of the size off of any implement based on what others say it will handle. We are on heavy clay loam, although it is very well tiled. Had a 115 horsepower Case in front of the 4-16 this fall and in several spots it was all the tractor could handle. Plow was adjusted properly.
Thanks for the help guys, I will probably see if I can borrow some implements from neighbours first just to see what the 2-105 will handle, don't want to invest in implements I can't pull  |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
