Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
charging problem
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
xring 223
PostPosted: Sat Feb 09, 2013 10:15 am    Post subject: charging problem Reply to specific post Reply with quote
newely rebuilt generator, new cut out, and a new amp meter. Single wire generator amp meter shows discharge when starting and more when lights are on. polarized at installation of generator. Why wont it charge or a least show charging
Den N Ms
PostPosted: Sat Feb 09, 2013 10:48 am    Post subject: Re: charging problem Reply to specific post Reply with quote
xring 223,To check things ,remove the belt from the generator pulley and jump across the two connection posts on the cutout with a short piece of wire ect.Does that make the generator motor?If not there is something wrong with the generator or wire connections.Post back.
Tom N MS
PostPosted: Sat Feb 09, 2013 10:49 am    Post subject: Re: charging problem Reply to specific post Reply with quote
With tractor running-use an analog meter and check across battery post-what reading do u get?
xring 223
PostPosted: Sat Feb 09, 2013 11:24 am    Post subject: Re: charging problem Reply to specific post Reply with quote
OK i checked voltage 8.40 I'm running 8V battery took belt off generator jumped relay and it ran in the direction of engine rotation
carlntexas
PostPosted: Sat Feb 09, 2013 11:39 am    Post subject: Re: charging problem Reply to specific post Reply with quote
The 8v battery is your problem generator won't charge an 8v.
xring 223
PostPosted: Sat Feb 09, 2013 11:50 am    Post subject: Re: charging problem Reply to specific post Reply with quote
really my brother has a 928N with an 8 volt batt. and his generator keeps it charged just fine
flembo
PostPosted: Sat Feb 09, 2013 12:35 pm    Post subject: Re: charging problem Reply to specific post Reply with quote
I see you put in a new amp meter could it be wired wrong.
flembo
PostPosted: Sat Feb 09, 2013 12:50 pm    Post subject: Re: charging problem Reply to specific post Reply with quote
SCRATCH MY POST 8 volt bat. and 8.4 volt reading not good. I didn't read your post well enough sorry.
souNdguy
PostPosted: Sat Feb 09, 2013 2:28 pm    Post subject: Re: charging problem Reply to specific post Reply with quote
for gennies with a vreg.. you have to tweak the vreg to get them to charge 8v.
in general.. 8v is a poor bandaid.
I'd make 6 work or go 12.
if it likes 8.. it will love 12...
xring 223
PostPosted: Sat Feb 09, 2013 2:33 pm    Post subject: Re: charging problem Reply to specific post Reply with quote
amp meter has + and - post neg ground system so battery side went to - post is this correct? like I said before when starting the meter shows discharge and turn lights on shows discharge also I took battery of and engine kuit and ideas
xring 223
PostPosted: Sat Feb 09, 2013 2:35 pm    Post subject: Re: charging problem Reply to specific post Reply with quote
I would like to keep it original how would you tweek a cutout relay doesn't have a vreg
souNdguy
PostPosted: Sat Feb 09, 2013 2:47 pm    Post subject: Re: charging problem Reply to specific post Reply with quote
you don't tweak a relay. a 1 wire genny has a 3rd brush you turn up.
Royse
PostPosted: Sat Feb 09, 2013 3:39 pm    Post subject: Re: charging problem Reply to specific post Reply with quote
What's the voltage at each terminal of your cutout relay when running?
I'm thinking your generator is charging fine and your cutout is not closing.
Wouldn't be the first bad new one I've heard about.
Ammeter discharges when lights are on sounds right to me.
It should bounce as the points open and close when cranking.
xring 223
PostPosted: Sat Feb 09, 2013 4:05 pm    Post subject: Re: charging problem Reply to specific post Reply with quote
I turned it up all the way
souNdguy
PostPosted: Sat Feb 09, 2013 5:09 pm    Post subject: Re: charging problem Reply to specific post Reply with quote
keep an eye on bat voltage at full charge.. don't want to boil it
Goto page 1, 2  Next
Page 1 of 2
