| Author |
Message |
RTIND Guest
Posted: Sat Feb 09, 2013 11:09 am Post subject: Old disc |
I have an old 1 pt disc. I guess it has a lot of dried up grease in it because it is very difficult to grease. Is it a problem to take the gang apart to scrape out the old stuff? |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50675 Location: Lake of the Ozarks area of MO
Posted: Sat Feb 09, 2013 11:42 am Post subject: Re: Old disc |
If it was mine I would heat up the grease areas then let it cool then try to grease it. A lot of time doing it that way will melt the old grease and in turn let it flow out so you can then grease it |
| Back to top |
Harvey 2 Regular
Posted: Sat Feb 09, 2013 2:09 pm Post subject: Re: Old disc |
You could buy what is called a grease buster. I think TSC sells them. You fill a container with your favorite panther pee and place it on the grease fitting and hit it with hammer which forces the penetrating oil in the fitting and driving out all the dirt and hard caked grease so that it will take grease. I don't have one, but I have been told it wyrks good. |
| Back to top |
ken house Regular
Posted: Sat Feb 09, 2013 5:01 pm Post subject: Re: Old disc |
some warm day, get it out and disc with it for 20 minutes or so and try to grease it then. |
| Back to top |
Tom Fleming Tractor Expert
Joined: 06 Jun 2007 Posts: 2076 Location: pennsylvania
Posted: Sun Feb 10, 2013 4:32 am Post subject: Re: Old disc |
I am with Old. Invest in a $9.95 propane soldering torch. Should be enough to do the whole thing. A little heat, then "pump 'er up".
I do that all the time with older fittings that I am not going to dismantle. Works well. Just make sure you start with a "clean" fitting. Also, make sure the check ball is working, and not stuck "open" and filled with grit. If that is the case, replace the fitting before proceeding. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
