Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
8N second gear
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
DonV
PostPosted: Sat Feb 09, 2013 12:29 pm    Post subject: 8N second gear Reply to specific post Reply with quote
Don"t have a second gear. Took off top plate, drained oil and everything seems to be there. Could it be an adjustment. Trying to avoid splitting the tractor.
souNdguy
PostPosted: Sat Feb 09, 2013 2:11 pm    Post subject: Re: 8N second gear Reply to specific post Reply with quote
is the shift fork actually engaging 2nd?
shift it in then pull the cover again..
Don Verrico
PostPosted: Sat Feb 09, 2013 2:33 pm    Post subject: Re: 8N second gear Reply to specific post Reply with quote
I don't know if it is. I'll shift it into second then pull the cover...what should I see?
Don Verrico
PostPosted: Sat Feb 09, 2013 2:38 pm    Post subject: Re: 8N second gear Reply to specific post Reply with quote
So I put the cover back on and when I put it in all the gears except 2nd it works fine. When I look at the gears including the two big ones on top they look fine. I put a magnet down onto the sump -- no metal. I drained all the fluid and everything looks OK.
souNdguy
PostPosted: Sat Feb 09, 2013 2:45 pm    Post subject: Re: 8N second gear Reply to specific post Reply with quote
look at your shift fork.
check the detents. is it slipping?
is the fork broke / bent?
DonV
PostPosted: Sat Feb 09, 2013 4:05 pm    Post subject: Re: 8N second gear Reply to specific post Reply with quote
I'm not sure what to look for. Everything seems OK.
souNdguy
PostPosted: Sat Feb 09, 2013 5:37 pm    Post subject: Re: 8N second gear Reply to specific post Reply with quote
thru the internet I won't be able to see your crashbox.
shift it into 2nd and look, then to neutral.
see if the box looks any different to you. Smile
Bill Rowles
PostPosted: Sat Feb 09, 2013 9:36 pm    Post subject: Re: 8N second gear Reply to specific post Reply with quote
You should be able to figure out which shift fork is moving when you move lever to "2". Then determine which gear that fork should move. Closely inspect both gear and fork. If the problem is not obvious to you, get someone more experienced to evaluate the situation.
Don Verrico
PostPosted: Sun Feb 10, 2013 5:59 am    Post subject: Re: 8N second gear Reply to specific post Reply with quote
I put gear shift lever into "2" and I can roll the tractor -- like it is in neutral. Take off the cover and look and everything looks OK. I can take a picture.
Don Verrico
PostPosted: Sun Feb 10, 2013 6:49 am    Post subject: Re: 8N second gear Reply to specific post Reply with quote
when I put the lever into 2nd it is not engaging. I pulled the cover again and took a picture...here it is. When I rock the tractor it rolls like it is in neutral.
souNdguy
PostPosted: Sun Feb 10, 2013 10:44 am    Post subject: Re: 8N second gear Reply to specific post Reply with quote
dude.. do some observation.
if you are shifting it and the gear is onviously not engaging, take a look at 'what' should be 'where' and solve for 'why not'
look for a slipped fork on a rail.. might be a set screw or something..
carlntexas
PostPosted: Sun Feb 10, 2013 1:15 pm    Post subject: Re: 8N second gear Reply to specific post Reply with quote
Am I the only one that can't see the picture?
Hobo,NC
PostPosted: Sun Feb 10, 2013 5:05 pm    Post subject: Re: 8N second gear Reply to specific post Reply with quote
Donv wrote:
(quoted from post at 00:29:13 02/10/13) Don"t have a second gear. Took off top plate, drained oil and everything seems to be there. Could it be an adjustment. Trying to avoid splitting the tractor.
Start look'n here...
http://www.oldfordtractors.com/2gears.htm
DonV
PostPosted: Sun Feb 10, 2013 5:46 pm    Post subject: Re: 8N second gear Reply to specific post Reply with quote
I think I figured it out..will see tomorrow. Looks like bottom of shift lever is worn out and not pushing the shift plate forward enough. I have another shift lever that I'm gonna try...
