| Author |
Message |
POPGUN Regular
Posted: Sat Feb 09, 2013 3:38 pm Post subject: old your opinion |
old look at heybusdrivers post "need expert advice" on 2-8-13 I told him you and Zane would have a good idea, I am also interested how one could solve the recessed broken stud in the block. TIA |
| Back to top |
heybusdriver Long Time User
Joined: 25 Nov 2000 Posts: 817 Location: Surrey B.C. Canada
Posted: Sat Feb 09, 2013 9:16 pm Post subject: Re: old your opinion |
I worked on it today , with the help from my brother (John Deere mechanic) I got the head back on , compression test tomorrow and then bolt the rest back up . I think we got it okay , time will tell soon . We drilled it out , didn't scalp any threads .
Stan
9N 222933
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039 |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50404 Location: Lake of the Ozarks area of MO
Posted: Sat Feb 09, 2013 9:58 pm Post subject: Re: old your opinion |
You say drilled it out explain what you did so it may help others. Left hand bit or what??? It helps others if you explain how you did something so then others may be able to use what you did the help them |
| Back to top |
TheOldHokie Tractor Guru
Joined: 08 Apr 2005 Posts: 5869 Location: Myersville, MD
Posted: Sun Feb 10, 2013 3:21 am Post subject: Re: old your opinion |
| POPGUN wrote: | | (quoted from post at 19:38:28 02/09/13) old look at heybusdrivers post "need expert advice" on 2-8-13 I told him you and Zane would have a good idea, I am also interested how one could solve the recessed broken stud in the block. TIA |
I have an old block and I intentionally snapped a few studs off in it to try different techniques:- You can easily to set the block on the table of a large drill press or mill. From there drilling/milling the bolt out is darn near trivial.
- I had high hopes for the "heat it and blow it out" with a cutting torch idea. My torch skills must need honing because I got the bolt out along with quite a bit of the bolt hole wall
 - Didn't have time to try the welded nut idea but I will when i get a chance. My welding skills are about on par with my cutting torch skills and all I have is an old Lincoln stick welder. I wouldn't even think about going after a bolt below the surface. I'd weld it to the block for sure.Film at 11.....
TOH |
| Back to top |
Posted: Sun Feb 10, 2013 8:02 am Post subject: Re: old your opinion |
I'd rather wait and see if we were successful, it's not like it was . give me a day or two. I may have to do more work on it, Thanks
Stan
9N 222933
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039 |
| Back to top |
L. B, Regular
Posted: Sun Feb 10, 2013 4:01 pm Post subject: Re: old your opinion |
Dont have the lg press or a mill. It was the bolt broke inside in a recess. I would only be able to drill it. ez out or tap. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
