| Author |
Message |
460anger Regular
Posted: Sun Feb 10, 2013 4:52 am Post subject: TO35 stuck in gear |
Can I knock the pin out take out gear shift lever re align the forks put it back together or is there more to it then that.I"am a farmall man thats how I do my M when it does this.Thanks |
| Back to top |
2tractors Long Time User
Posted: Sun Feb 10, 2013 5:41 am Post subject: Re: TO35 stuck in gear |
Plenty of help in the archives, just type in "stuck in gear" in the search block. Some have used a screwdriver thru the filler cap. |
| Back to top |
460anger Regular
Posted: Sun Feb 10, 2013 6:23 am Post subject: Re: TO35 stuck in gear |
ok thanks |
| Back to top |
maxwell99 Long Time User
Posted: Sun Feb 10, 2013 12:10 pm Post subject: Re: TO35 stuck in gear |
take trans oil filler cap off
stick a long strong screwdriver into hole and work shifter rods back and fore.
hopefully the trans shifter will unlock and you will be good to go.
when shifting make a effort to never, never pull up on the long shifter rod when shifting.
always use some down pressure or just side pressure, but it seems like pulling up on the shifter lever when shifting will lock the gears.
shifter rods are worn and you can live with it, if you learn to not pull up on shifter.
after you unlock it a few times, old dogs can learn new tricks, and not pull up on lever.
good luck and let us know how it works out for you.
when was oil in trans/hyd system changed, may be time for a little maintenance. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
