Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
H block
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling
Farmallhelp
PostPosted: Wed Feb 13, 2013 1:35 pm    Post subject: H block Reply to specific post Reply with quote
Hi! I have a Farmall H block that was stroked. Ground for clearence and ground pin hole thru into water jacket, We brazed it up. Now got it together and running and getting antifreeze in oil. I found seeping around brazed area. I have water jacket cover off side of block and it is leaking on same side. Is there something I can pour in to seal the little seepage I have? Should I put some hard bloc in bottom or will stop leak in antifreeze work? Wondering if there was something that can be poured in and dries then can put antifreeze back in. Any ideas appreciated. Thanks
VicS
PostPosted: Wed Feb 13, 2013 5:46 pm    Post subject: Re: H block Reply to specific post Reply with quote
I have took the head off of a Allis and poured K&N block sealer in straight. I put a Quart in around the sleeves, Let it set for about 3 days, that was 8 or 9 years ago. Has held antifreeze ever since. You can use hyd oil for coolant. 300 deg is nothing. Some real big Olivers running that way. If you don't want to take it apart, Water Glass or egg preservative. (get it at a drug store) I used a quart in a 423 U Moline. It had a cracked head.
iH welker
PostPosted: Wed Feb 13, 2013 6:10 pm    Post subject: Re: H block Reply to specific post Reply with quote
Hard blok is the stuff you want to use !!!! I used it on mine and it worked great ground through 3 different places put tape over them until hard and no leaks at all .
mattwillson
PostPosted: Wed Feb 13, 2013 7:45 pm    Post subject: Re: H block Reply to specific post Reply with quote
get a bottle of irontite and follow instructions, you should be okay after that
IHSMOKE
PostPosted: Thu Feb 14, 2013 7:49 am    Post subject: Re: H block Reply to specific post Reply with quote
hard block if to just below the water jacket plate ...make it real soupy pour in my m running that way
Farmallhelp
PostPosted: Thu Feb 14, 2013 6:20 pm    Post subject: Re: H block Reply to specific post Reply with quote
Thanks for replies, think hard bloc will work. Just needed few extra opinions. Thanks again
puller1
PostPosted: Sat Feb 16, 2013 5:25 am    Post subject: Re: H block Reply to specific post Reply with quote
If you hard block you need to rebore the cylinders. It will change the shape of the bore as it swells and contracts while setting up.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
