| Author |
Message |
Dave Sherburne NY Tractor Expert
Posted: Wed Feb 13, 2013 3:29 pm Post subject: K301 Piston and Rod. |
I've got parts coming hopefully tomorrow for this engine. I see marks on the rod that go toward the flywheel during reassembly . I see no marks on the old piston. Does it make a difference which way it goes on the rod? |
| Back to top |
David G Tractor Guru
Posted: Wed Feb 13, 2013 6:17 pm Post subject: Re: K301 Piston and Rod. |
Check the crank, they get out of round. |
| Back to top |
Traper Regular
Posted: Wed Feb 13, 2013 6:56 pm Post subject: Re: K301 Piston and Rod. |
Dave
If piston is round at wrist pin direction either way.If flat must go one way just ran into this on a k241 traper |
| Back to top |
t.r.k. Guest
Posted: Fri Feb 15, 2013 6:05 pm Post subject: Re: K301 Piston and Rod. |
If you are replacing the piston, I think the new one will be marked. If you want to re-use the old piston and its still on the rod, mark it with a scribe or a center punch.
If you are trying to re-use the old piston, be sure your rings fit the piston. Parts book shows 'early' and 'late' but fail to say that early is .096 width compression rings and late is .063 width.
As far as the rod goes, the oil hole goes toward the camshaft. This should put the marks you see on the flywheel side. |
| Back to top |
Greenday Long Time User
Joined: 08 Jun 2008 Posts: 1402 Location: NW Missouri
Posted: Sun Feb 17, 2013 5:43 am Post subject: Re: K301 Piston and Rod. |
David G is right. Have the crank checked. These engines dont tolerate much wear on the crank before you will start getting a faint knock. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
