| Author |
Message |
Thomas(AB) Regular
Joined: 30 Mar 2012 Posts: 77 Location: Fort Saskatchewan AB
Posted: Thu Feb 14, 2013 7:03 am Post subject: Generator vs Alternator |
My generator has died, and is unrebuildable. Theres a fellow about an hour from me who builds custom alternators, he can build a self regulating 6volt positve ground for around 140 dollars. as this will mean i can stop replacing voltage regulators every year, im thinking about going this route. Thoughts? |
| Back to top |
Duner Wi Tractor Expert
Posted: Thu Feb 14, 2013 7:25 am Post subject: Re: Generator vs Alternator |
It is not uncommon to rebuild the GM 10 and 12 si to 6-8-12-24 volt with either neg or pos ground.
If 6 volt positive Gr fulfils your needs I would say do it. Most folk go with 12 volt neg Gr. |
| Back to top |
jon corbett Regular
Posted: Thu Feb 14, 2013 3:25 pm Post subject: Re: Generator vs Alternator |
only 1 problem-nothig runs on 6 volt,u wanna use electric winch?nope.electic anything?nope,12 volt for me and the te. |
| Back to top |
bobs old iron Tractor Expert
Posted: Thu Feb 14, 2013 3:57 pm Post subject: Re: Generator vs Alternator |
i'll like to ask a question too,, not using a winch, etc, and not changing anything,,would i have to rewire around v/r, remove wires or what do i have to do, if i change out to alt.. my to-20 is still 6-v pos gd genny... |
| Back to top |
Thomas(AB) Regular
Posted: Thu Feb 14, 2013 7:06 pm Post subject: Re: Generator vs Alternator |
well all this tractor does is run a sickle mower, and deal with the bigger snowfalls. However it is stored inside in the winter, i have a winch on my truck, so i think i will stay with the 6 volt system.
To change to a 12 volt system, i have done it on another tractor, you need a new coil or a resistor in line, adjust your points, and dont over crank your starter, very easy to burn it out with 12 volts. |
| Back to top |
Tom H. Regular
Posted: Fri Feb 15, 2013 6:09 pm Post subject: Re: Generator vs Alternator |
Do it. Unless your going to show the tractor and be a purist I would upgrade to the alternator, actually I did. I put an 8 volt pos ground in my TO30 and am very happy. The original parts are stored so if I need to I can go back to original.
My two cents |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
