Brinly planter
Goto page 1, 2  Next
66jd1020
PostPosted: Fri Feb 15, 2013 6:44 am    Post subject: Brinly planter Reply to specific post Reply with quote
Sorry. I did not get the photo uploaded on the last post:
I have this Brinly planter that was given to me. I cannot find the model number on it. The front plow sweep is mounted different than most I have seen. It is missing the hitch plates only has one seed plate. Any help would be appreciated.
Harvey 2
PostPosted: Fri Feb 15, 2013 7:55 am    Post subject: Re: Brinly planter Reply to specific post Reply with quote
Looks like it needs a lot of help. I don't know the model # ; I would be interested in purchasing it from you. Where are you located?
66jd1020
PostPosted: Fri Feb 15, 2013 8:00 am    Post subject: Re: Brinly planter Reply to specific post Reply with quote
It does look rough. The fertilizer hopper may never work again but the seed operation seems to work fine. I am not interesting in selling it. It was given to me by a family member.
El Toro
PostPosted: Fri Feb 15, 2013 8:14 am    Post subject: Re: Brinly planter Reply to specific post Reply with quote
I had a bracket made for my moldboard plow similar to the one on your planter so it would be easier to install on my sleeve hitch. Your bracket is made from heavier metal. I drilled and tapped the sleeve hitch, but that was pain when installing or removing the plow bracket. Hal
El Toro
PostPosted: Fri Feb 15, 2013 8:18 am    Post subject: Re: Brinly planter Reply to specific post Reply with quote
A little paint and elbow grease it will look new.
Hal
PS: My tractor and plow after painting.
66jd1020
PostPosted: Fri Feb 15, 2013 8:19 am    Post subject: Re: Brinly planter Reply to specific post Reply with quote
I have been thinking about getting it welded as one piece if I can't reproduce the original configuration. Thanks.
Tom Arnold
PostPosted: Fri Feb 15, 2013 9:32 am    Post subject: Re: Brinly planter Reply to specific post Reply with quote
That is, IMO, a Brinly KK-520 Vegetable Planter with Fertilizer Canister but I could be wrong.
Tthe two canisters appear to be mounted incorrectly. The tall one should be directly above the wheel and it should have feed plate mounted on the opposite side shown in your photo that drops down to a sort of coulter disc mounted on a bracket bolted to the side of the frame. The plow sweep seems to be incorrect for the KK-520 as it used what they called a "depth gauge". .
There were 5 seed plates included with that planter along with 3 "distance sprockets" that determined how far apart the seeds were planted. There were also 11 other seed plates available as optional equipment. If you send an e-mail to Judy at Brinly, she will provide you with 2 PDF's of the original Parts Manual for this planter.
jbabcock@brinly.com
For all those reading this thread, I have found the people at Brinly to be exceptionally helpful and I have nothing but praise for them and this amazing company.
66jd1020
PostPosted: Fri Feb 15, 2013 10:45 am    Post subject: Re: Brinly planter Reply to specific post Reply with quote
Thanks for that information. I have e emailed contact for Brinly. When I spoke to them on the phone yesterday, they were not helpful and stated that they did not support planters anymore.
When I first got this planter, there was a flexible seed tube behind the front sweep. As you noticed, it is inconsistent with other planters.
DiyDave
PostPosted: Fri Feb 15, 2013 4:09 pm    Post subject: Re: Brinly planter Reply to specific post Reply with quote
Those were made by cole-powell co. The company is still in business, name has changed, I think, in GA, google around, lots of farm equipment dealers sell parts, Plates run around $20 average, EBAY lists several, most of the time, but it's cheaper through a dealer, IMHO.
Traditional Farmer
PostPosted: Sun Feb 17, 2013 5:47 am    Post subject: Re: Brinly planter Reply to specific post Reply with quote
The last time I talked to the Cole folks they said they weren't making anymore of the older style plates and only going to sell off of the stock they now have.Also there are several variations of the Brinly/Cole planter plates and they will not interchange.
DiyDave
PostPosted: Sun Feb 17, 2013 6:01 am    Post subject: Re: Brinly planter Reply to specific post Reply with quote
Yes, there are 2 (I think) types of Cole/Powell plates, the smaller ID one, and the lagger ID one, for the big Cole vegetable planters. The brinley takes 3" center hole plates. Might be getting scarce, now, but if there is a demand, you could replicate them in plastic.
Traditional Farmer
PostPosted: Sun Feb 17, 2013 11:31 am    Post subject: Re: Brinly planter Reply to specific post Reply with quote
I know of 3 different sizes in the Brinly planters the first ones used a square drive in the center and then the two different centers.Is someone making Brinly plates in plastic? I've never seen any.I did buy out an EX Brinly dealer in a vegetable growing area and got some nice unique plates around 200 of them.There were according to the Brinly manuals I have 126 different plate planting variations made for those planters.
DiyDave
PostPosted: Sun Feb 17, 2013 4:41 pm    Post subject: Re: Brinly planter Reply to specific post Reply with quote
For the record, I no of no one currently making plastic ones. What I meant, is that these planters will always have a value, hence there will always be a market for plates. Making these plates in plastic, would not be hard to do, is what I am saying.
bill stewart
PostPosted: Mon Feb 18, 2013 7:09 am    Post subject: Re: Brinly planter Reply to specific post Reply with quote
hi there i have a chance to buy a couple of one row brinly seeders with fertilizer spreaders would u be interested in selling a few of the plates p.s.not just sure of the makes thanks
Traditional Farmer
PostPosted: Mon Feb 18, 2013 3:09 pm    Post subject: Re: Brinly planter Reply to specific post Reply with quote
Probably someone sooner or later will come up the plastic plates I guess.I adapted a John Deere 71 planter to Cat 0 3pt and like it better planting with a garden tractor than the Brinly Planter plus JD plates are everywhere but not cheap even the plastic ones.
Goto page 1, 2  Next
Page 1 of 2
