Oliver 88 gear box removal
AllisWC puller
PostPosted: Fri Feb 15, 2013 12:41 pm    Post subject: Oliver 88 gear box removal Reply to specific post Reply with quote
Trying to figure out how I remove the gear box housing on my Oliver 88 where the belt pulley goes
J. Schwiebert
PostPosted: Sat Feb 16, 2013 3:05 am    Post subject: Re: Oliver 88 gear box removal Reply to specific post Reply with quote
Do you have an I & T manual? Look up how install a clutch. Sheet metal and fuel tank will need to be removed as well as the fuel tank. Instrument panel will need to be folded over the engine. Long PTO shaft needs to be removed. Then coupler needs to be unhooked. Then unbolt the housing. You will need to have a seal retainer to replace the pulley housing as well as a couple of plugs to cap some openings. A couple hours you will be done.
Bryce
PostPosted: Sat Feb 16, 2013 5:21 am    Post subject: Re: Oliver 88 gear box removal Reply to specific post Reply with quote
If you disconnect the steering shaft there is no need to move the the dash.
