Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Farmall 400 Power Steering?
Tinks
PostPosted: Fri Feb 15, 2013 5:45 pm    Post subject: Farmall 400 Power Steering? Reply to specific post Reply with quote
I am trying to cut out the hydralic reservoir between the steering column and the gas tank. I know that I will have to make a bracket to hold the gas tank and the steering wheel. I am wanting to know if I can run the power steering directly off of the live hydralics pump. Will the power steering work like that or not? And if so how do I make it work?
TJV
PostPosted: Fri Feb 15, 2013 6:33 pm    Post subject: Re: Farmall 400 Power Steering? Reply to specific post Reply with quote
i think that if you run the pump directly from the pump you will have too many gallons per minute as the flow divider sends a galloln or two to the steering and the rest to the hydraulic system you will still need a reservior for oil or the few ounces of oil it takes to just fill the hoses will get hot very fast. just my thoughts and if they are wrong someone please correct me,
armand tatro
PostPosted: Fri Feb 15, 2013 7:10 pm    Post subject: Re: Farmall 400 Power Steering? Reply to specific post Reply with quote
Why in the world would you want to do away with the hyd. tank?! Armand
Nebraska Kirk
PostPosted: Fri Feb 15, 2013 7:47 pm    Post subject: Re: Farmall 400 Power Steering? Reply to specific post Reply with quote
Tinks wrote:
(quoted from post at 19:45:16 02/15/13) I am trying to cut out the hydralic reservoir between the steering column and the gas tank. I know that I will have to make a bracket to hold the gas tank and the steering wheel. I am wanting to know if I can run the power steering directly off of the live hydralics pump. Will the power steering work like that or not? And if so how do I make it work?
No, that will not work. As others have stated the pump puts out a lot more flow than the power steering system needs, without a reservoir the oil will overheat. If I were you I would get a power steering pump that has it's own reservoir. Maybe even adapt a GM power steering pump to run your power steering, my brother used one on his M, works pretty good.
D Slater
PostPosted: Sat Feb 16, 2013 7:04 am    Post subject: Re: Farmall 400 Power Steering? Reply to specific post Reply with quote
Can't say I would recommend it but a fellow had a M with the same pump that only supplied the power steering and used it for years. It was one of the behlen steering units with the built in reservoir housing. Steered like a dream.
If you want to try you need some kind of fluid reservoir and at least a cross over relief valve between pressure and suction lines.
Must be a puller if you want to remove those parts, most also go to manual steering to save a little more weight and the power lost to turn the pump.
