SUPER M
Bud Kaiser
PostPosted: Sat Feb 16, 2013 6:25 am    Post subject: SUPER M Reply to specific post Reply with quote
Does anyone know the number of the brake seal and where to get one?I have a NAPA store in town.
Janicholson
PostPosted: Sat Feb 16, 2013 6:57 am    Post subject: Re: SUPER M Reply to specific post Reply with quote
169948C91 is a replacement part for the obsolete part(s) 357037R91
Taken from the on line parts manual. NAPA has crossovers. Jim
D Slater
PostPosted: Sat Feb 16, 2013 7:16 am    Post subject: Re: SUPER M Reply to specific post Reply with quote
You can do it yourself. Put NAPA in the search box, go to online parts catalog. Upper right enter part # 357037R91 in the search box, click interchange box then search. Should be seeing the NAPA seal number. If you enter a store near you before searching it will also give you the price. Most times the NAPA interchange still uses old IH numbers. But if a first you fail try another number for the same seal or change the suffix up or down a number or letter a few places.
Bob M
PostPosted: Sat Feb 16, 2013 7:17 am    Post subject: Re: SUPER M Reply to specific post Reply with quote
Bud - Take the IHC seal p/n (357 037 R91) to NAPA. They can cross it to another mfr's equivalent and order it for you. (I believe Timken #450316 is one equivalent - there are several others).
Keep in mind the new seal will be only 1/2 the thickness of the original. Can either install two seals in the counterbore and fill the space between the 2 seals with grease **OR** install a single seal positioned so the lip rides on an unworn area of the bull pinion shaft.
I prefer the latter option.
D Slater
PostPosted: Sat Feb 16, 2013 11:30 am    Post subject: Re: SUPER M Reply to specific post Reply with quote
Have to be some kind of special thinner seals to fit in for a SM bull pinion shaft. Original seal only had about a 1/2 inch wide shell. Never bought a replacement thin enough anyway.
